(SOLVED)M5Stack WIFI Upload file on SD in AP mode
  • Hi all I'm looking for a way to upload files on M5Stack SD with M5Stack in Acces point mode....
    Is it possible?
    I tried this but without success ( I know this is not access point mode but it could be a starting point..)
    Connecting ...
    Connected to myWifi Use IP address: 192.168.0.150
    Initializing SD card...Card initialised... file access enabled...
    HTTP server started
    this is the serial monitor output:
    This site can’t be reached192.168.0.150 took too long to respond.
    Try:
    Checking the connection
    Checking the proxy and the firewall
    ERR_CONNECTION_TIMED_OUT
    pc and M5Stack are in the same wifi network..
    I'm in the Arduino ecosistem..
    tnks a lot
  • This one work on M5Stack!!!!!
    #include "M5Stack.h"
    #include <WiFi.h>
    #include <WiFiClient.h>
    #include <WebServer.h>
    #define ServerVersion "1.0"
    String webpage = "";
    bool   SD_present = false;
    #include "index.h"  //Web page header file
    WebServer server(80);
    // Setup
    void setup(void) {
      Serial.begin(115200);
      Serial.println();
      Serial.println("Booting Sketch...");
      //ESP32 As access point IP: 192.168.4.1
      WiFi.mode(WIFI_AP); //Access Point mode
      WiFi.softAP("ESPWebServer", "12345678");    //Password length minimum 8 char
      Serial.print(F("Initializing SD card..."));
      if (!SD.begin(TFCARD_CS_PIN, SPI, 40000000)) { // see if the card is present and can be initialised. Wemos SD-Card CS uses D8
        Serial.println(F("Card failed or not present, no SD Card data logging possible..."));
        SD_present = false;
      else
        Serial.println(F("Card initialised... file access enabled..."));
        SD_present = true;
      ///////////////////////////// Server Commands
      server.on("/",         HomePage);
      server.on("/download", File_Download);
      server.on("/upload",   File_Upload);
      server.on("/fupload",  HTTP_POST, []() {
        server.send(200);
      }, handleFileUpload);
      ///////////////////////////// End of Request commands
      server.begin();
      Serial.println("HTTP server started");
    // This routine is executed when you open its IP in browser
    void loop(void) {
      server.handleClient();
      delay(1);
    // All supporting functions from here...
    void HomePage() {
      SendHTML_Header();
      webpage += F("<a href='/download'><button>Download</button></a>");
      webpage += F("<a href='/upload'><button>Upload</button></a>");
      append_page_footer();
      SendHTML_Content();
      SendHTML_Stop(); // Stop is needed because no content length was sent
    void File_Download() { // This gets called twice, the first pass selects the input, the second pass then processes the command line arguments
      if (server.args() > 0 ) { // Arguments were received
        if (server.hasArg("download")) SD_file_download(server.arg(0));
      else SelectInput("Enter filename to download", "download", "download");
    void SD_file_download(String filename) {
      if (SD_present) {
        File download = SD.open("/" + filename);
        if (download) {
          server.sendHeader("Content-Type", "text/text");
          server.sendHeader("Content-Disposition", "attachment; filename=" + filename);
          server.sendHeader("Connection", "close");
          server.streamFile(download, "application/octet-stream");
          download.close();
        } else ReportFileNotPresent("download");
      } else ReportSDNotPresent();
    void File_Upload() {
      append_page_header();
      webpage += F("<h3>Select File to Upload</h3>");
      webpage += F("<FORM action='/fupload' method='post' enctype='multipart/form-data'>");
      webpage += F("<input class='buttons' style='width:40%' type='file' name='fupload' id = 'fupload' value=''><br>");
      webpage += F("<br><button class='buttons' style='width:10%' type='submit'>Upload File</button><br>");
      webpage += F("<a href='/'>[Back]</a><br><br>");
      server.send(200, "text/html", webpage);
    File UploadFile;
    void handleFileUpload() { // upload a new file to the Filing system
      HTTPUpload& uploadfile = server.upload(); // See https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266WebServer/srcv
      // For further information on 'status' structure, there are other reasons such as a failed transfer that could be used
      if (uploadfile.status == UPLOAD_FILE_START)
        String filename = uploadfile.filename;
        if (!filename.startsWith("/")) filename = "/" + filename;
        Serial.print("Upload File Name: "); Serial.println(filename);
        SD.remove(filename);                         // Remove a previous version, otherwise data is appended the file again
        UploadFile = SD.open(filename, FILE_WRITE);  // Open the file for writing in SPIFFS (create it, if doesn't exist)
        filename = String();
      else if (uploadfile.status == UPLOAD_FILE_WRITE)
        if (UploadFile) UploadFile.write(uploadfile.buf, uploadfile.currentSize); // Write the received bytes to the file
      else if (uploadfile.status == UPLOAD_FILE_END)
        if (UploadFile)         // If the file was successfully created
          UploadFile.close();   // Close the file again
          Serial.print("Upload Size: "); Serial.println(uploadfile.totalSize);
          webpage = "";
          webpage += F("<h3>File was successfully uploaded</h3>");
          webpage += F("<h2>Uploaded File Name: "); webpage += uploadfile.filename + "</h2>";
          webpage += F("<h2>File Size: "); webpage += file_size(uploadfile.totalSize) + "</h2><br>";
        else
          ReportCouldNotCreateFile("upload");
    void SendHTML_Header() {
      server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate");
      server.sendHeader("Pragma", "no-cache");
      server.sendHeader("Expires", "-1");
      server.setContentLength(CONTENT_LENGTH_UNKNOWN);
      server.send(200, "text/html", ""); // Empty content inhibits Content-length header so we have to close the socket ourselves.
      server.sendContent(webpage);
      webpage = "";
    void SendHTML_Content() {
      webpage = "";
    void SendHTML_Stop() {
      server.sendContent("");
      server.client().stop(); // Stop is needed because no content length was sent
    void SelectInput(String heading1, String command, String arg_calling_name) {
      SendHTML_Header();
      webpage += F("<h3>"); webpage += heading1 + "</h3>";
      webpage += F("<FORM action='/"); webpage += command + "' method='post'>"; // Must match the calling argument e.g. '/chart' calls '/chart' after selection but with arguments!
      webpage += F("<input type='text' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>");
      webpage += F("<type='submit' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>");
      webpage += F("<a href='/'>[Back]</a>");
      SendHTML_Content();
      SendHTML_Stop();
    void ReportSDNotPresent() {
      SendHTML_Header();
      webpage += F("<h3>No SD Card present</h3>");
      SendHTML_Content();
      SendHTML_Stop();
    void ReportFileNotPresent(String target) {
      SendHTML_Header();
      webpage += F("<h3>File does not exist</h3>");
      webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>";
      SendHTML_Content();
      SendHTML_Stop();
    void ReportCouldNotCreateFile(String target) {
      SendHTML_Header();
      webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>");
      SendHTML_Content();
      SendHTML_Stop();
    String file_size(int bytes) {
      String fsize = "";
      if (bytes < 1024)                 fsize = String(bytes) + " B";
      else if (bytes < (1024 * 1024))      fsize = String(bytes / 1024.0, 3) + " KB";
      else if (bytes < (1024 * 1024 * 1024)) fsize = String(bytes / 1024.0 / 1024.0, 3) + " MB";
      else                              fsize = String(bytes / 1024.0 / 1024.0 / 1024.0, 3) + " GB";
      return fsize;
    and this is the page
    void append_page_header() {
      webpage  = F("<!DOCTYPE html><html>");
      webpage += F("<head>");
      webpage += F("<title>File Server</title>"); // NOTE: 1em = 16px
      webpage += F("<meta name='viewport' content='user-scalable=yes,initial-scale=1.0,width=device-width'>");
      webpage += F("<style>");
      webpage += F("body{max-width:65%;margin:0 auto;font-family:arial;font-size:105%;text-align:center;color:blue;background-color:#F7F2Fd;}");
      webpage += F("ul{list-style-type:none;margin:0.1em;padding:0;border-radius:0.375em;overflow:hidden;background-color:#dcade6;font-size:1em;}");
      webpage += F("li{float:left;border-radius:0.375em;border-right:0.06em solid #bbb;}last-child {border-right:none;font-size:85%}");
      webpage += F("li a{display: block;border-radius:0.375em;padding:0.44em 0.44em;text-decoration:none;font-size:85%}");
      webpage += F("li a:hover{background-color:#EAE3EA;border-radius:0.375em;font-size:85%}");
      webpage += F("section {font-size:0.88em;}");
      webpage += F("h1{color:white;border-radius:0.5em;font-size:1em;padding:0.2em 0.2em;background:#558ED5;}");
      webpage += F("h2{color:orange;font-size:1.0em;}");
      webpage += F("h3{font-size:0.8em;}");
      webpage += F("table{font-family:arial,sans-serif;font-size:0.9em;border-collapse:collapse;width:85%;}");
      webpage += F("th,td {border:0.06em solid #dddddd;text-align:left;padding:0.3em;border-bottom:0.06em solid #dddddd;}");
      webpage += F("tr:nth-child(odd) {background-color:#eeeeee;}");
      webpage += F(".rcorners_n {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:75%;}");
      webpage += F(".rcorners_m {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:50%;color:white;font-size:75%;}");
      webpage += F(".rcorners_w {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:70%;color:white;font-size:75%;}");
      webpage += F(".column{float:left;width:50%;height:45%;}");
      webpage += F(".row:after{content:'';display:table;clear:both;}");
      webpage += F("*{box-sizing:border-box;}");
      webpage += F("footer{background-color:#eedfff; text-align:center;padding:0.3em 0.3em;border-radius:0.375em;font-size:60%;}");
      webpage += F("button{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:130%;}");
      webpage += F(".buttons {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:80%;}");
      webpage += F(".buttonsm{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:9%; color:white;font-size:70%;}");
      webpage += F(".buttonm {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:70%;}");
      webpage += F(".buttonw {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:40%;color:white;font-size:70%;}");
      webpage += F("a{font-size:75%;}");
      webpage += F("p{font-size:75%;}");
      webpage += F("</style></head><body><h1>File Server "); webpage += String(ServerVersion) + "</h1>";
    void append_page_footer(){ // Saves repeating many lines of code for HTML page footers
      webpage += F("<ul>");
      webpage += F("<li><a href='/'>Home</a></li>"); // Lower Menu bar command entries
      webpage += F("<li><a href='/download'>Download</a></li>");
      webpage += F("<li><a href='/upload'>Upload</a></li>");
      webpage += F("</ul>");
      webpage += "<footer>&copy;"+String(char(byte(0x40>>1)))+String(char(byte(0x88>>1)))+String(char(byte(0x5c>>1)))+String(char(byte(0x98>>1)))+String(char(byte(0x5c>>1)));
      webpage += String(char((0x84>>1)))+String(char(byte(0xd2>>1)))+String(char(0xe4>>1))+String(char(0xc8>>1))+String(char(byte(0x40>>1)));
      webpage += String(char(byte(0x64/2)))+String(char(byte(0x60>>1)))+String(char(byte(0x62>>1)))+String(char(0x70>>1))+"</footer>";
      webpage += F("</body></html>");
