<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED]M5Stack basic I2C pull-up resistor]]></title><description><![CDATA[<p dir="auto">Hi all, are they present the pull-up resistors in the M5Stack (black 2018.3) I2C section?<br />
I'm trying to read <a href="https://www.robot-electronics.co.uk/htm/srf10tech.htm" target="_blank" rel="noopener noreferrer nofollow ugc">this US sensor</a> but I don't know if add or not pull-up resistors.....</p>
<p dir="auto">tnks</p>
]]></description><link>https://community.m5stack.com/topic/1762/solved-m5stack-basic-i2c-pull-up-resistor</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 07:36:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1762.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Mar 2020 15:37:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED]M5Stack basic I2C pull-up resistor on Thu, 19 Mar 2020 15:44:49 GMT]]></title><description><![CDATA[<p dir="auto">tnks a lot!!!</p>
]]></description><link>https://community.m5stack.com/post/7828</link><guid isPermaLink="true">https://community.m5stack.com/post/7828</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Thu, 19 Mar 2020 15:44:49 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]M5Stack basic I2C pull-up resistor on Thu, 19 Mar 2020 12:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cepics" aria-label="Profile: cepics">@<bdi>cepics</bdi></a> The default resistance is 3.3k. you cannot disable it.   If you want to dismantle it. Operation will be more difficult</p>
]]></description><link>https://community.m5stack.com/post/7825</link><guid isPermaLink="true">https://community.m5stack.com/post/7825</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 19 Mar 2020 12:17:26 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]M5Stack basic I2C pull-up resistor on Thu, 19 Mar 2020 10:27:58 GMT]]></title><description><![CDATA[<p dir="auto">tnks a lot!!,<br />
wich value?<br />
can I disable it?<br />
I'm in Arduino ecosystem ...</p>
]]></description><link>https://community.m5stack.com/post/7821</link><guid isPermaLink="true">https://community.m5stack.com/post/7821</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Thu, 19 Mar 2020 10:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]M5Stack basic I2C pull-up resistor on Thu, 19 Mar 2020 01:50:25 GMT]]></title><description><![CDATA[<p dir="auto">it  already has pull up resistors in G21/22 ( the I2C PIN)</p>
]]></description><link>https://community.m5stack.com/post/7818</link><guid isPermaLink="true">https://community.m5stack.com/post/7818</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 19 Mar 2020 01:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]M5Stack basic I2C pull-up resistor on Wed, 18 Mar 2020 17:28:52 GMT]]></title><description><![CDATA[<p dir="auto">nobody??</p>
]]></description><link>https://community.m5stack.com/post/7814</link><guid isPermaLink="true">https://community.m5stack.com/post/7814</guid><dc:creator><![CDATA[cepics]]></dc:creator><pubDate>Wed, 18 Mar 2020 17:28:52 GMT</pubDate></item></channel></rss>
