<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Yun and ESPnow project]]></title><description><![CDATA[<p dir="auto">This is my test code so far. more info to come.<br />
StickC with YUN</p>
from m5ui import *
from uiflow import *
import espnow
import wifiCfg
import hat
setScreenColor(0x111111)
hat_yun0 = hat.get(hat.YUN)
wifiCfg.wlan_ap.active(True)
espnow.init()
label0 = M5TextBox(70, 16, "Text", lcd.FONT_Default,0xFFFFFF, rotate=90)
label1 = M5TextBox(53, 17, "Text", lcd.FONT_Default,0xFFFFFF, rotate=90)
label2 = M5TextBox(35, 17, "Text", lcd.FONT_Default,0xFFFFFF, rotate=90)
label3 = M5TextBox(19, 17, "Text", lcd.FONT_Default,0xFFFFFF, rotate=90)
label4 = M5TextBox(21, 117, "Text", lcd.FONT_Default,0xFFFFFF, rotate=90)
espnow.add_peer('80:7d:3a:db:e2:19', id=1)
label0.setText(str(espnow.get_mac_addr()))
while True:
  label1.setText(str(hat_yun0.temperature))
  espnow.broadcast(data=str((hat_yun0.temperature)))
  label2.setText(str(hat_yun0.humidity))
  espnow.broadcast(data=str((hat_yun0.humidity)))
  label3.setText(str(hat_yun0.pressure))
  espnow.broadcast(data=str((hat_yun0.pressure)))
  label4.setText(str(hat_yun0.getLight()))
  espnow.broadcast(data=str((hat_yun0.getLight())))
  wait_ms(2)
<p dir="auto">And on the core side</p>
from m5ui import *
import espnow
import wifiCfg
setScreenColor(0x222222)
espnow.init()
label0 = M5TextBox(29, 6, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
label1 = M5TextBox(23, 47, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
label2 = M5TextBox(26, 95, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
label3 = M5TextBox(17, 134, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
label4 = M5TextBox(20, 172, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
sentmp = None
sen01 = None
sunhum = None
senpre = None
def recv_cb(_):
  global sentmp,sen01,sunhum,senpre
  sen01, _, sentmp = espnow.recv_data(encoder='str')
  wait_ms(100)
  label1.setText(str(sen01))
  label2.setText(str(sentmp))
  label3.setText(str(sunhum))
  label4.setText(str(senpre))
  pass
espnow.recv_cb(recv_cb)
]]></description><link>https://community.m5stack.com/topic/1885/yun-and-espnow-project</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 05:24:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1885.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Apr 2020 17:57:11 GMT</pubDate><ttl>60</ttl></channel></rss>
