<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which M5Stack Gray hardware revision do I have?]]></title><description><![CDATA[<p dir="auto">Hi there</p>
<p dir="auto">I am wondering if it is possible to figure out exactly which M5Stack Gray hardware revision I have.<br />
According to the Quick Start guide some hardware changes have been made over time:</p>
<li>2017.9   Initial public release</li>
<li>2017.12  MPU6050+MAG3110 changed to MPU9250</li>
<li>2019.6   MPU9250 changed to MPU6886+BMM150</li>
<li>2019.7   TN screen changed to IPS screen</li>
<li>2020.3   Battery capacity changed from 150mAh to 110mAh</li>
<p dir="auto">Here is what I know about my unit:</p>
<li>bought from a local dealer on July 2020</li>
<li>board reads: 2018.3</li>
<li>IP5306 can be controlled via I2C</li>
<li>MPU6886 and BMM150 included on daughter board</li>
<li>IPS screen (I guess as it is quite good, but I have nothing to compare about)</li>
<li>battery reads: 150mAh</li>
<p dir="auto">Assuming I am correct about the IPS screen that would put my unit between 2019.7 and 2020.3.</p>
<p dir="auto">Are there any other indicators that would tell me more about my unit?</p>
<li>For instance, are there newer boards than 2018.3 out there?</li>
<li>Are MPU6886 and BMM150 integrated on newer boards (assuming they exist)?</li>
<li>Is there a specific schematic for the M5Stack Gray (including MPU6886 and BMM150)? The only schematic I found so far is for M5Stack Basic Core (and w/o MPU6886 or BMM150)</li>
]]></description><link>https://community.m5stack.com/topic/2195/which-m5stack-gray-hardware-revision-do-i-have</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 18:44:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2195.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2020 08:26:00 GMT</pubDate><ttl>60</ttl></channel></rss>
