<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5camera supply.]]></title><description><![CDATA[<p dir="auto">May be a silly question but,<br />
Can i use both the USB and grove connection to supply power to the camera at the same time?</p>
]]></description><link>https://community.m5stack.com/topic/315/m5camera-supply</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 11:54:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/315.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Sep 2018 14:21:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5camera supply. on Fri, 21 Sep 2018 05:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/1565">M5camera supply.</a> 中说：</p>
<p dir="auto">Yes, it is. But be careful that you must ensure the supply of USB and GROVE must be common-ground and the supply can not be too high. Otherwise, the power chip of M5Camera will be burnt.</p>
<p dir="auto">Ah, there in lies the problem,<br />
I was going to use the USB to draw power from the laptop and the Grove to draw power from an auxiliary battery pack.</p>
]]></description><link>https://community.m5stack.com/post/1567</link><guid isPermaLink="true">https://community.m5stack.com/post/1567</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 21 Sep 2018 05:14:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5camera supply. on Fri, 21 Sep 2018 02:30:25 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it is. But be careful that you must ensure the supply of USB and GROVE must be common-ground and the supply can not be too high. Otherwise, the power chip of M5Camera will be burnt.</p>
]]></description><link>https://community.m5stack.com/post/1565</link><guid isPermaLink="true">https://community.m5stack.com/post/1565</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 21 Sep 2018 02:30:25 GMT</pubDate></item></channel></rss>
