<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Arducam (arduino) Can&#x27;t find OV2640 module!]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> Have you guys got any idea how to get the arducam esp32 examples working on the M5Camera (2nd version)?</p>
]]></description><link>https://community.m5stack.com/topic/419/arducam-arduino-can-t-find-ov2640-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 04:58:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/419.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Nov 2018 09:12:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Arducam (arduino) Can&#x27;t find OV2640 module! on Sat, 08 Dec 2018 17:29:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/133419">@watson</a> 在 <a href="/post/2085">Arducam (arduino) Can't find OV2640 module!</a> 中说：</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a><br />
Here's the pinmap about camera supplied by m5stack.</p>
<p dir="auto"><a href="https://github.com/m5stack/M5-Schematic/blob/master/Units/m5camera/hardware_diff_with_ESP32CAM_M5Camera.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic/blob/master/Units/m5camera/hardware_diff_with_ESP32CAM_M5Camera.md</a></p>
<p dir="auto">That doesn't tie up because the arducams arduino_pin.h has D2 as I/O12<br />
and slave select as I/O17</p>
]]></description><link>https://community.m5stack.com/post/2152</link><guid isPermaLink="true">https://community.m5stack.com/post/2152</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 08 Dec 2018 17:29:39 GMT</pubDate></item><item><title><![CDATA[Reply to Arducam (arduino) Can&#x27;t find OV2640 module! on Mon, 26 Nov 2018 02:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a><br />
]]></description><link>https://community.m5stack.com/post/2085</link><guid isPermaLink="true">https://community.m5stack.com/post/2085</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 26 Nov 2018 02:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Arducam (arduino) Can&#x27;t find OV2640 module! on Mon, 26 Nov 2018 02:47:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a><br />
Hi, I have not tried ArduCAM. But once I'm free, I'll try that.</p>
]]></description><link>https://community.m5stack.com/post/2083</link><guid isPermaLink="true">https://community.m5stack.com/post/2083</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 26 Nov 2018 02:47:26 GMT</pubDate></item><item><title><![CDATA[Reply to Arducam (arduino) Can&#x27;t find OV2640 module! on Sun, 25 Nov 2018 12:41:32 GMT]]></title><description><![CDATA[<pre><code>// ArduCAM Mini demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with ArduCAM ESP32 2MP/5MP camera.
// This demo was made for ArduCAM ESP32 2MP/5MP Camera.
// It can take photo and send to the Web.
// It can take photo continuously as video streaming and send to the Web.
// The demo sketch will do the following tasks:
// 1. Set the camera to JPEG output mode.
// 2. if server receives "GET /capture",it can take photo and send to the Web.
// 3.if server receives "GET /stream",it can take photo continuously as video
//streaming and send to the Web.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM ESP32 2MP/5MP camera
// and use Arduino IDE 1.8.1 compiler or above
#include &lt;WiFi.h&gt;
#include &lt;Wire.h&gt;
#include &lt;ESP32WebServer.h&gt;
#include &lt;ArduCAM.h&gt;
#include &lt;SPI.h&gt;
#include "memorysaver.h"
#if !(defined ESP32 )
#error Please select the ArduCAM ESP32 UNO board in the Tools/Board
#endif
//This demo can only work on OV2640_MINI_2MP or ARDUCAM_SHIELD_V2 platform.
#if !(defined (OV2640_MINI_2MP)||defined (OV5640_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP_PLUS) \
    || defined (OV5642_MINI_5MP) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) \
    ||(defined (ARDUCAM_SHIELD_V2) &amp;&amp; (defined (OV2640_CAM) || defined (OV5640_CAM) || defined (OV5642_CAM))))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
// set GPIO17 as the slave select :
const int CS = 17;
const int CAM_POWER_ON = D10;
#if defined (OV2640_MINI_2MP) || defined (OV2640_CAM)
  ArduCAM myCAM(OV2640, CS);
#elif defined (OV5640_MINI_5MP_PLUS) || defined (OV5640_CAM)
  ArduCAM myCAM(OV5640, CS);
#elif defined (OV5642_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) ||(defined (OV5642_CAM))
  ArduCAM myCAM(OV5642, CS);
#endif
//you can change the value of wifiType to select Station or AP mode.
//Default is AP mode.
int wifiType = 1; // 0:Station  1:AP
//AP mode configuration
//Default is arducam_esp8266.If you want,you can change the AP_aaid  to your favorite name
const char *AP_ssid = "M5Cam";
//Default is no password.If you want to set password,put your password here
const char *AP_password = NULL;
//Station mode you should put your ssid and password
const char *ssid = "SSID"; // Put your SSID here
const char *password = "PASSWORD"; // Put your PASSWORD here
static const size_t bufferSize = 2048;
static uint8_t buffer[bufferSize] = {0xFF};
uint8_t temp = 0, temp_last = 0;
int i = 0;
bool is_header = false;
ESP32WebServer server(80);
void start_capture(){
  myCAM.clear_fifo_flag();
  myCAM.start_capture();
void camCapture(ArduCAM myCAM){
WiFiClient client = server.client();
uint32_t len  = myCAM.read_fifo_length();
if (len &gt;= MAX_FIFO_SIZE) //8M
  Serial.println(F("Over size."));
if (len == 0 ) //0 kb
  Serial.println(F("Size is 0."));
myCAM.CS_LOW();
myCAM.set_fifo_burst();
if (!client.connected()) return;
String response = "HTTP/1.1 200 OK\r\n";
response += "Content-Type: image/jpeg\r\n";
response += "Content-len: " + String(len) + "\r\n\r\n";
server.sendContent(response);
i = 0;
while ( len-- )
temp_last = temp;
temp =  SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) &amp;&amp; (temp_last == 0xFF) ) //If find the end ,break while,
buffer[i++] = temp;  //save the last  0XD9
//Write the remain bytes in the buffer
if (!client.connected()) break;
client.write(&amp;buffer[0], i);
is_header = false;
i = 0;
myCAM.CS_HIGH();
break;
if (is_header == true)
//Write image data to buffer if not full
if (i &lt; bufferSize)
buffer[i++] = temp;
else
//Write bufferSize bytes image data to file
client.write(&amp;buffer[0], bufferSize);
i = 0;
buffer[i++] = temp;
else if ((temp == 0xD8) &amp; (temp_last == 0xFF))
is_header = true;
buffer[i++] = temp_last;
buffer[i++] = temp;
void serverCapture(){
  delay(1000);
start_capture();
Serial.println(F("CAM Capturing"));
int total_time = 0;
total_time = millis();
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
total_time = 0;
Serial.println(F("CAM Capture Done."));
camCapture(myCAM);
Serial.print(F("send total_time used (in miliseconds):"));
Serial.println(F("CAM send Done."));
void serverStream(){
response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
while (1){
start_capture();
size_t len = myCAM.read_fifo_length();
continue;
continue;
myCAM.CS_LOW();
response = "--frame\r\n";
response += "Content-Type: image/jpeg\r\n\r\n";
while ( len-- )
temp_last = temp;
myCAM.CS_HIGH();;
is_header = false;
i = 0;
buffer[i++] = temp;
else
myCAM.CS_HIGH();
i = 0;
buffer[i++] = temp;
myCAM.CS_LOW();
is_header = true;
buffer[i++] = temp;
void handleNotFound(){
String message = "Server is running!\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
server.send(200, "text/plain", message);
Serial.println(message);
if (server.hasArg("ql")){
int ql = server.arg("ql").toInt();
myCAM.OV2640_set_JPEG_size(ql);
myCAM.OV5640_set_JPEG_size(ql);
#elif defined (OV5642_MINI_5MP_PLUS) || defined (OV5642_MINI_5MP_BIT_ROTATION_FIXED) ||(defined (OV5642_CAM))
myCAM.OV5642_set_JPEG_size(ql);
#endif
Serial.println("QL change to: " + server.arg("ql"));
uint8_t vid, pid;
uint8_t temp;
  //set the CS as an output:
  pinMode(CS,OUTPUT);
  pinMode(CAM_POWER_ON , OUTPUT);
  digitalWrite(CAM_POWER_ON, HIGH);
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.begin(115200);
Serial.println(F("ArduCAM Start!"));
// initialize SPI:
SPI.begin();
SPI.setFrequency(4000000); //4MHz
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55){
Serial.println(F("SPI1 interface Error!"));
while(1);
if (temp != 0x55){
while(1);
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &amp;vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &amp;pid);
if ((vid != 0x26 ) &amp;&amp; (( pid != 0x41 ) || ( pid != 0x42 )))
Serial.println(F("Can't find OV2640 module!"));
else
Serial.println(F("OV2640 detected."));
Serial.print ("vid = ");
Serial.println (vid);
Serial.print ("pid = ");
Serial.println (pid);
//Check if the camera module type is OV5640
myCAM.wrSensorReg16_8(0xff, 0x01);
myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &amp;vid);
myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &amp;pid);
if((vid != 0x56) || (pid != 0x40))
Serial.println(F("Can't find OV5640 module!"));
else
Serial.println(F("OV5640 detected."));
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &amp;vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &amp;pid);
if((vid != 0x56) || (pid != 0x42)){
Serial.println(F("Can't find OV5642 module!"));
else
Serial.println(F("OV5642 detected."));
#endif
//Change to JPEG capture mode and initialize the OV2640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_320x240);
myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
myCAM.OV5640_set_JPEG_size(OV5640_320x240);
myCAM.OV5640_set_JPEG_size(OV5642_320x240);
#endif
if (wifiType == 0){
if(!strcmp(ssid,"SSID")){
Serial.println(F("Please set your SSID"));
while(1);
if(!strcmp(password,"PASSWORD")){
Serial.println(F("Please set your PASSWORD"));
while(1);
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.print(F("Connecting to "));
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(F("."));
Serial.println(F("WiFi connected"));
Serial.println("");
Serial.println(WiFi.localIP());
}else if (wifiType == 1){
Serial.println();
Serial.println();
Serial.print(F("Share AP: "));
Serial.println(AP_ssid);
Serial.print(F("The password is: "));
Serial.println(AP_password);
WiFi.mode(WIFI_AP);
WiFi.softAP(AP_ssid, AP_password);
Serial.println("");
Serial.println(WiFi.softAPIP());
// Start the server
server.on("/capture", HTTP_GET, serverCapture);
server.on("/stream", HTTP_GET, serverStream);
server.onNotFound(handleNotFound);
server.begin();
Serial.println(F("Server started"));
    server.handleClient();
]]></description><link>https://community.m5stack.com/post/2079</link><guid isPermaLink="true">https://community.m5stack.com/post/2079</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 25 Nov 2018 12:41:32 GMT</pubDate></item></channel></rss>
