<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to connect the COM.X NB IoT and use is for mqtt or other requests]]></title><description><![CDATA[<p dir="auto">I have an Core2 and the COM.X NB IoT with an unlocked SIM card for a data connection. Now I would setup an wifi access point and for internet connectivity I would use the 3G connection.</p>
<p dir="auto">How can I use this module in UI Flow to get the connection .. for example to connect to an mqtt broker like I would do when the Core2 is connected to wifi? And maybe all other connected wifi clients can directly communicate with the internet and.</p>
]]></description><link>https://community.m5stack.com/topic/4655/how-to-connect-the-com-x-nb-iot-and-use-is-for-mqtt-or-other-requests</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 20:42:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4655.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Sep 2022 17:50:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to connect the COM.X NB IoT and use is for mqtt or other requests on Tue, 08 Nov 2022 00:28:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mchott" aria-label="Profile: mchott">@<bdi>mchott</bdi></a></p>
<p dir="auto">in my experience a data SIM (for smartphones, LTE routers, etc.) is not good enough for NB-IoT. You will need a SIM card specifically for NB-IoT plus the NB-IoT service needs to be offered by the provider in your region.</p>
]]></description><link>https://community.m5stack.com/post/19232</link><guid isPermaLink="true">https://community.m5stack.com/post/19232</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 08 Nov 2022 00:28:31 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the COM.X NB IoT and use is for mqtt or other requests on Mon, 07 Nov 2022 15:17:52 GMT]]></title><description><![CDATA[<p dir="auto">The first thing is the mismatch between the dip switch setting and the real setting for TX/RX with the Core2. If you have the Core2 TX:14 and RX:13 is the correct connection. After that I "Check module status" with success and "true". But the Network registration and GPRS network registration is 0 and the signal quality is 99. After that I tested my SIM in other devices and this is not the problem.</p>
<p dir="auto">But there is no connection. Still an red led and an blinking blue led.</p>
]]></description><link>https://community.m5stack.com/post/19230</link><guid isPermaLink="true">https://community.m5stack.com/post/19230</guid><dc:creator><![CDATA[mchott]]></dc:creator><pubDate>Mon, 07 Nov 2022 15:17:52 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect the COM.X NB IoT and use is for mqtt or other requests on Tue, 27 Sep 2022 19:13:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mchott" aria-label="Profile: mchott">@<bdi>mchott</bdi></a></p>
<p dir="auto">in UIFlow 1.10.x have you tried the MQTT blocks under <code>Modules - COM.X -  NB-IoT</code>?</p>
]]></description><link>https://community.m5stack.com/post/18743</link><guid isPermaLink="true">https://community.m5stack.com/post/18743</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 27 Sep 2022 19:13:20 GMT</pubDate></item></channel></rss>
