    analogRead on M5Atom
    3 Posts 3 Posters 13.3k Views
      sbollaerts
      Hello, I'm trying to make analog readings on pin "G33" and "G23".
      • When I do analogRead(33), I get the same values whatever I send the signal on G33 or G23
      • When I do analogRead(23), I receive no signal on G33 and G23
      What am I missing?
      #if !defined(ARDUINO_M5Stick_C)
      #error Wrong target platform (M5StickC - M5Atom)
      #endif
      #include "M5Atom.h"
      #include "pixelTypes.h"
      uint8_t pinNorth = 33;
      //uint8_t pinSouth = 19;
      void setup()
      M5.begin(false, false, true);
      Serial.begin(115200);
      void loop()
      int readValue;
      int ledValue;
      // Read the North pin
      readValue = analogRead(pinNorth);
      ledValue = map(readValue, 0, 4095, 0, 255);
      Serial.print("- North: ");
      Serial.print(readValue);
      Serial.print(" -> ");
      Serial.println(ledValue);
      M5.dis.drawpix(2, ledValue);
      M5.dis.drawpix(6, ledValue);
      M5.dis.drawpix(7, ledValue);
      M5.dis.drawpix(8, ledValue);
      delay(10);
      // Read the South pin
      // readValue = analogRead(pinSouth);
      // ledValue = map(readValue, 0, 4095, 0, 255);
      // Serial.print("- South: ");
      // Serial.print(readValue);
      // Serial.print(" -> ");
      // Serial.println(ledValue);
      // M5.dis.drawpix(16, ledValue);
      // M5.dis.drawpix(17, ledValue);
      // M5.dis.drawpix(18, ledValue);
      // M5.dis.drawpix(22, ledValue);
      // Serial.println("");
      // delay(10);
        AndyT @sbollaerts
        @sbollaerts
        Are you usiing a gpio that does not have a ADC?
        Ah yes GPIO19 is not an ADC pin.
        here is a picture of the pins of the M5Stack
        https://www.instructables.com/Automation-With-SIM800L-ESP32-M5Stack/
        PINS 35 or 36 are the ADC's
        • felmueF Online
          Hello @sbollaerts
          there is only one analog input available on the M5Atom Matrix: GPIO34 which is shared with GPIO23.
          Please check out M5AtomMatrix Schematic
          In order to use the analog input you'll need to set GPIO34 as input and disable pullup/pulldown resistors of GPIO23.
          Below code works for me:
          #include <M5Atom.h>
          void setup()
            M5.begin(true, false, true);
            pinMode(GPIO_NUM_34, INPUT);
            gpio_pulldown_dis(GPIO_NUM_23);
            gpio_pullup_dis(GPIO_NUM_23);
          void loop()
            Serial.printf("GPIO34: %d\n", analogRead(GPIO_NUM_34));
            delay(1000);
          Update: I just realised that GPIO33 can also be used as analog input.
            pinMode(GPIO_NUM_33, INPUT);
            Serial.printf("GPIO33: %d\n", analogRead(GPIO_NUM_33));
          Cheers
