    Store and reopen IMU data on SD card
    Units
    5.8k
    • J
      jsh
      Hello everyone,
      I am programming a M5Stack in the Arduino IDE. I want to read the acceleration data of the installed IMU, save it on the SD card, open it again and edit it. Using the example sketches of Arduino I can do all this. But my problem is that I can't edit the data further. I would like to sum up all recorded accX, accY and accZ values one by one. I have tested this for the accX values, but nothing comes out right. My goal is to integrate the data to get a total value for the speed of one-dimensional linear movements.
      Can someone tell me how I can only access the saved and reopened values of my SD card?
      Here is my code:
      //© by Jan-Soeren Henning
      #define M5STACK_MPU6886
      #include <M5Stack.h>
      #include "FS.h"
      #include "SD.h"
      #include "SPI.h"
      #include "time.h"
      #include "math.h"
      float accX = 0.0F;
      float accY = 0.0F;
      float accZ = 0.0F;
      float zeit = 0.0F;
      float testX = 0.0F;
      char msg[100];
      unsigned long zeit_start = 0.0;
      unsigned long zeit_end = 0.0;
      boolean button_a = false;
      boolean measurement = false;
      boolean start = true;
      void writeFile(fs::FS &fs, const char * path, const char * message){
      Serial.printf("Writing file: %s\n", path);
      File file = fs.open(path, FILE_WRITE);
      if(!file){
          Serial.println("Failed to open file for writing");
          return;
      if(file.print(message)){
          Serial.println("File written");
      } else {
          Serial.println("Write failed");
      file.close();
      void appendFile(fs::FS &fs, const char * path, const char * message){
      Serial.printf("Appending to file: %s\n", path);
      File file = fs.open(path, FILE_APPEND);
      if(!file){
          Serial.println("Failed to open file for appending");
          return;
          Serial.println("Message appended");
      } else {
          Serial.println("Append failed");
      file.close();
      void readFile(fs::FS &fs, const char * path){
      Serial.printf("Reading file: %s\n", path);
      File file = fs.open(path);
      if(!file){
      Serial.println("Failed to open file for reading");
      return;
      Serial.print("Read from file:\n ");
      while(file.available()){
      Serial.write(file.read());
      testX = testX + (abs(accX));
      file.close();
      M5.Power.begin();
      M5.IMU.Init();
      M5.Lcd.println("Press button A to\nstart measurement");
      Serial.begin(115200);
      if(!SD.begin()){
      Serial.println("Card Mount Failed");
      return;
      uint8_t cardType = SD.cardType();
      if(cardType == CARD_NONE){
          Serial.println("No SD card attached");
          return;
      Serial.print("SD Card Type: ");
      if(cardType == CARD_MMC){
          Serial.println("MMC");
      } else if(cardType == CARD_SD){
          Serial.println("SDSC");
      } else if(cardType == CARD_SDHC){
          Serial.println("SDHC");
      } else {
          Serial.println("UNKNOWN");
      writeFile(SD, "/acceleration.txt", "   Time    aX       aY        aZ");
      while (start){
       zeit_start = millis();
       if (M5.BtnA.wasReleasefor(70))
               button_a = (!(button_a));
               measurement = (!(measurement));
        if (button_a)
          while (measurement)
                zeit_end = millis()-zeit_start;
                M5.IMU.getAccelData(&accX,&accY,&accZ);
                snprintf(msg, 100, "\r\n  %5.2lf   %5.2lf     %5.2lf     %5.2lf",zeit, accX, accY, accZ);    // => Daten lesen mit sscanf?????
                appendFile(SD, "/acceleration.txt", msg);
                      readFile(SD, "/acceleration.txt");
                      Serial.println(" ");
                      Serial.println(testX);
        Hi @jsh
        in your readFile() function try something like this to sum up accX into testX:
          testX = 0.0;
            // read zeit - skip over
            file.parseFloat();
            // read accX - sum up
            testX = testX + file.parseFloat();
            // read accY - skip over
            file.parseFloat();
            // read accZ - skip over
            file.parseFloat();
        instead of
        Good luck!
        Cheers
        • J
          jsh
          Hallo @felmue
          I have tried it and it works, thanks for the quick help!!!
          I am glad that I can finally continue working on my program :)
