Ah yes, success! I added
ez.addEvent(run_Blynk);
to thesetup()
, and then created a function down below, after the loop, that looks like the following. It's worth noting that I'm using the M5 as a "receiver" from a bridge, thus the blynk_write(V1) statement.uint16_t run_Blynk() { Blynk.run(); return 1; } BLYNK_WRITE(V1){ eventData = param.asString(); }
That did the trick, Blynk connects and stays connected. Now trying to figure out how to display the dynamic data from Blynk on the canvas. If I figure this all out, I'll write a short demo in a new topic for others, as I haven't seen many examples of actual use of M5ez, other than the demo program, but most projects are more than just menus, they have to display something... Again, @rop, excellent work, and thanks again so much!
I really like M5ez so I gave it its own core. Justified it by saying that’s real MVC architecture! Real Computer Science stuff.
GLOBAL INFO
core 0 is the communications processor.
Uses the ESP-NOW protocol
on the 2.4 GHz radio
This process runs as a task created
on core 1
core 1 is the UI processor.
Maintains the M5Stack M5ez LCD menu
Runs Arduino setup() and loop()
Use RTOS semaphores when accessing the global vars to/from the local versions.
Is there a chance to change font (or size) of ez.header ?
Regards, M
Looks great! Does it play well with PlatformIO ?
Great Job
@Rop is M5EZ supporting the Stick C?
I have had a query from the Facebook group.
No it does not: it only works on the 3-Button M5Stack devices.
@rop Any intention of a stick version?
@brianr @rop Hey guys, thanks a lot for this very elegant solution, I´m using the ezMenu library in a program where I had installed Blynk working very well but everytime when I activated the ezMenu with mainmenu.run(); my Blynk app was very unstable, with the trick of ez.addEvent(run_Blynk) in the setup() function now is working very well, thanks for the help
great project.
It is possible to use the face encoder for up, down and enter?
if yes, you have an example?
this will be great
It is great using the M5EZ!
But I want / need to give my Core a static IP address. Is there an easy way to alter the Wifi settings menu and add the option of adding static ip? Maybe In such a way it is stored in the preferences?kr, G
I wanted to know if there is a way to use faces keyboard in the menus (i.e. I have the calculator keyboard and instead of using the three buttons to go up and down and select, I want to use the keys on the face, for example for selecting first line I will type on the key '1' and so on).
and if it is possible, can you give me an example of code using it.
How do i get the characters for my region such as the pound sign £ ?
