    IR Block not available
    Bug Report
    2.1k
    • D
      Dave_White
      Hi there,
      UI Flow and IR capability were my reasons for buying a M5Stack C Plus.
      I would like you to add the missing block in order to finish the hardware list.
      Thank you
      David Blanco
        Hello @Dave_White
        in the mean time you could use Advanced - PIN and setup GPIO9 (IR) as pin0 / output and then set pin0 LOW to turn the IR LED on.
        Below MicroPython code lets the IR LED blink:
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import machine
        import time
        setScreenColor(0x111111)
        pin0 = machine.Pin(9, mode=machine.Pin.OUT, pull=0x00)
        while True:
          pin0.off()
          wait(1)
          pin0.on()
          wait(1)
        Cheers
