    51 Posts 14 Posters 357.5k Views 7 Watching
    • 1nformatica1 Offline
      1nformatica @Calin
      @calin Hi, any timeframe for when you may be able to change to OpenWeather? I have just done an overview video on YouTube and next want to review the individual Apps. It would be really neat if the weather App was working. Thanks.
      M5Stack MultiApp Advanced Firmware Installation Tutorial Guide
        Calin @1nformatica
        @1nformatica The weather app is currently working just fine with weatherunderground service.
        There was a compatibility problem with the latest IDF version but i fixed that last week.
        If you really whant to use the openweather, i can add the option for openweather till tomorrow... but i am not sure how the service quality is on that provider... and if they provide all the data used on this app
        1nformatica1 1 Reply Last reply Reply Quote 0
          1nformatica @Calin
          @calin From WeatherUnderground's web site "To improve our services and enhance our relationship with our users, we will no longer provide free weather API keys as part of our program. If you have been directed to download our Weather Underground free API key by a third party provider, please contact your vendor for resolution."
            Calin
            Ok. The new weather app is under testing... I will upload it soon to github.
              1nformatica @Calin
              @calin Wow! That was quick, much appreciated.
                Calin @1nformatica
                @1nformatica The openweather don't provide so much data... so i have to do some extended redesign on the weather app to make it look nice. Until then, i added my (working) WU key to repository so you can try the weather app.
                  Kryten @Calin
                  @calin
                  Would it be much hassel to add in the webserver WiFi settings (For those times WPS is not available) and
                  Weather settings (API key, language, country and city)
                    Calin @Kryten
                    @kryten
                    • If your router don't support WPS, you can use the SmartConfig app on the phone to connect the M5Stack to Wifi
                    • Weather settings are already implemented. Read the project description.
                      At the Weather Station chapter you can find info about WeatherParams.txt file and how to use it.
                      Kryten @Calin
                      @calin Yes I saw this after I postede, sorry.
                      This is really good work by the way ;)
                        1nformatica
                        Hi All, I have just uploaded a video review of the Apps to Youtube Apps Review
                        I made a silly mistake with the oscilloscope App as of course it cannot handle negative going inputs!!
                          Calin @1nformatica
                          @1nformatica You didn't apply the PlatformIO patch and you are getting the BtnA (left key) unwanted "presses".
                          M5Stack use GPIO39 for BtnA.
                          There is a bug on arduino-esp32 framework that cause interference between Wifi and GPIO39.
                          That patch contain arduino-esp32 precompiled libraries that don't have this bug.
                          Since the libraries came precompiled, i don't have access to the code to find what's causing that bug and fix the problem.
                          • KabronK Offline
                            Kabron
                            Hello, Calin,
                            I allowed myself a tiny mod to your App. Now it can be launched from the SD card under SD-Menu from tobozo. https://github.com/tobozo/M5Stack-SD-Updater.
                            Modification consists in main.c mod and extra libraries. Just unzip Matroska.zip to project folder and build. Resulting firmware.bin in .pioenvs\m5stack-core-esp32
                            is compatible with tobozo loader.
                            Zip here:
                            https://yadi.sk/d/8sroLeG_3YMfwe
                              Calin @Kabron
                              @kabron you can do that if you whant for your M5Stack.
                              @tobozo can make a repository that contain this mods too.
                              I won't do that because i need every bit of flash memory for the apps that i am working on...
                              I just updated MultiApp.
                              • Added Tetris game with score and high score counter.
                              • Fixed some bugs related to fonts
                              Getting closer to flash size limit...
                              • KabronK Offline
                                Kabron @Calin
                                @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                                With one tiny exception:
                                Tobozo's app does not restart menu with BtnA+Reset
                                  picpic020960
                                  sad that the pre-compiled firmware is no longer available.
                                  when will he come back
                                  thanks
                                    Calin @picpic020960
                                    @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
                                    thanks
                                    Install VsCode, PlatformIO, then flash the project to M5Stack.
                                    Is a straight forward procedure.
                                    I removed the pre-compiled firmware because the M5Stack had to be formatted with a specific partition table for pre-compiled firmware to work.
                                      picpic020960
                                      no is straight forward with corporate proxy !
                                      old version of pre-compiled firmware work fine.
                                      why partition issue ?
                                      [pre-compiled firmware is best for MultiApp popularity]
                                      thanks
                                        Calin @picpic020960
                                        Well... yeah... you are right on this one...
                                        thanks
                                        Ok... i will bring it back later today...
                                          picpic020960
                                          Hi Calin
                                          tested last night ! sync , download , finish , reset and ... black screen
                                          maybe my error : use the old [not Advanced] FLASH_DOWNLOAD_TOOLS_V3.6.4.zip
                                          other way : 'old MultiApp' is OK without SD card and no jpg , maybe 'Advanced' no ?
                                          more : windows 10 (on thomson tablet)
                                          my fear :have bad clone !
                                          I test again tonight
                                          Regards
                                            Calin @picpic020960
                                            Hi Calin
                                            Regards
                                            As i told you... the best solution is to COMPILE the project on PlatformIO.
                                            The M5Stack came with default factory partitions table.
                                            That partition table is incompatible with MultiApp-Advanced firmware.
                                            Old MultiApp firmware use standard partitions table and that's why that precompiled binary work.
                                            The precompiled firmware only write the application data. So precom piled binary will be useful only if you try to update the multiapp-advanced firmware to a newer version.
                                            Will NOT work if you try to write the multiapp-advanced over a different application.
                                            On MultiApp-advanced i use a custom partition table that is written if you compile and upload the project from PlatformIO.
