    How to center a text?
    FAQS
    34.1k
    • P
      PépéMax
      Hello everyone,
      Quiz, I have a question, how can I do to center my text on the screen.
      My code:void Display_WiFi_Connected() {
      M5.Lcd.clear(BLACK);
      M5.Lcd.setTextSize(2);
      M5.Lcd.print("M5Stack has been connected");
      I know I can use the function M5.Lcd.setCursor(); but I would like it to center my text according to its size ????
      • reaper7R
        reaper7
        use:
        setTextDatum(uint8_t datum);
        https://github.com/m5stack/M5Stack/blob/master/src/utility/In_eSPI.h#L554
        and available options:
        https://github.com/m5stack/M5Stack/blob/master/src/utility/In_eSPI.h#L331
        • P
          PépéMax
          Thank you so much, I did'nt see this function
          But where should I put the function in my code?
          • C
            Calin @PépéMax
            @pépémax 在 How to center a text? 中说:
            Hello everyone,
            Try this:
            M5.Lcd.drawCentreString("your string", x, y, font);
            So your code should be:
            M5.Lcd.drawCentreString("M5Stack has been connected", 160, 120, 2);
            to write a string size 2 on the center of the screen.
            You also have the option to write a right aligned string.
            I love reading C++ headers :)
            • reaper7R
              reaper7
              For safe use in the future, better way is:
                M5.Lcd.setTextDatum(CC_DATUM);
                M5.Lcd.drawString("M5Stack has been connected", 160, 120, 2);
              because drawCentreString is marked as deprecated
              • P
                PépéMax @reaper7
                @reaper7 @Calin Thanks mens
                but my text was not center in my display
                I think it's because of 160 and 120 values.
                I would like my text to be centered in height and width.
                • reaper7R
                  reaper7
                  what is your screen orientation? landscape or portrait ??
                  where is your text?
                  try to swap values 160 with 120 for portrait mode
                  or use this instead:
                  M5.Lcd.drawString("M5Stack has been connected", (int)(M5.Lcd.width()/2), (int)(M5.Lcd.height()/2), 2);
                  which calculates values for current orientation.
                  I do not have hw for tests
                  • P
                    PépéMax
                    Excuse me but it's my fault
                    • reaper7R
                      reaper7
                      but it's working or not?
                      • P
                        PépéMax
                        Yes yes it's working
