Send AT Command va UIFlow
i have a M5Core device.
Yes, i switch from TX23 -> to TX17, and RX19 -> to 16. Thanks for this tip.
But, now i have a last question, see screenshot below.
I Arduino i write with Serial2.write(...) the Hex. How can i do this in the UIFLOW ?!Please see screenshots...
Hope you can help me, with my last question...
Hello @TheAlphaGhost
the block you are using actually writes a string "0xFA" but you want the raw hex value.
I see two options:
- convert the hex values into decimal values, then use a UART - write raw data block or
- try an Advanced - Execute code block with:
uart1.write(b'\xFA')
Note: untested as I don't have the required hardware.
Good luck!
Hi Felix,
Vielen dank für Deine Unterstützung ! Sprichst du deutsch ?
Thanks for your help. I will try both options, and will send a feedback here.
Mhh, still not work. Don't know what's wrong...
I think the problem is now with
uart1.write(ServoID)
. Eg. sending values from a variable. When I try this, the receiving end gets a string instead of the hex value.Unfortunately I am not a Python expert - I tried a few things but nothing seems to work. Sorry about that.
Hi Felix,
no problem. Will try to find the error...
Thanks for your help!!
Hallo Felix,
now it's work, with byte array...
nice, congratulations and thanks for sharing. Thanks to you I've learned something new today.
Happy Stacking!
I wish the blocks were in English so I don’t have to Google Translate it all 🤣🤣🤣.
Kidding though. I can tell by the block colors what’s going on. Nice job fixing it!
Uhh, sorry. Here the english version...
