    IP5306 automatic standby
    20 Posts 10 Posters 96.1k Views 5 Watching
    • on4aaO Offline
      on4aa
      According to the data sheet (in Chinese language only by the way),
      if the load current drops below 45mA during 32 seconds, the IP5306 goes into standby.
      This is useful information for making some sort of heartbeat circuit to keep the IP5306 from going into standby.
      Serge — http://hamwaves.com/iot/
        Pelocks
        Any ideas to avoid automatic standby?
        i am working with deepsleep and it wont wakeup above 30seconds setup.
        Thanks!!!
          Pelocks
          Are 2018 models came with the same IP5306 stand by setup?
          Could it be customized for big orders?
          Thanks guys
          • loborisL Offline
            loboris @Pelocks
            @pelocks 在 IP5306 automatic standby 中说:
            Thanks guys
            2018 models have the same problem with IP5306 standby.
            You can't get very low power consumption in deepsleep with M5Stack anyway, so waking up every 30 seconds, checking the elapsed time and going to deepsleep immediately if needed won't make much difference.
            • m5stackM Online
              hi there, i had ordered 4k pcs ip5306_i2C, and change the newest board for this, so the new model can close this function.
              loborisL 1 Reply Last reply Reply Quote 1
              • reaper7R Offline
                reaper7
                @m5stack - very good news!
                P.S. please also check the quality of connectors, especially female (on master board),
                maybe only my m5stack has such a problem but from the beginning of use, various pins have a contact problem
                with bottom plates(I check different: ioExtension/proto board/battery board).
                Evidently male pins from bottom plates do not have good contact with female connector on base plate, I do not check all contacts but have problem with accu pin, adc35 pin, adc36 pin.
                it's very annoying and spoils the positive impression from the module
                when you can not read the input status and wonder what is wrong in the code
                and it's not the fault of the code but the lack of contact
                P.S.P.S please also vote for this PR: https://github.com/espressif/arduino-esp32/pull/1242
                because current version of board.txt do not include proper pins_arduino.h variant for m5stack and for e.g. ADC1 or ADC2 are unknown when compile
                • loborisL Offline
                  loboris @m5stack
                  @m5stack 在 IP5306 automatic standby 中说:
                  Great news, but make shure that the new board is degned in a way that the total power consumption of all the additional circuitry (except ESP32 itself) can be reduced to at least <100 uA, otherwise it wont be very useful.
                  • vshymanskyyV Offline
                    vshymanskyy
                    @JiKuch , @loboris, @m5stack, @JimiT
                    Does anyone have a list of all I2C registers of IP5306_I2C (preferably, in english)?
                    Also, what is the I2C address of this chip? I tried running I2C scanner and I get:
                      0x68 => MPU9250
                      0x0E => MAG3110
                      0x75 => IP5306 ???
                    Correct me if I'm wrong.
                    J E 3 Replies Last reply Reply Quote 0
                      JiKuch @vshymanskyy
                        JiKuch @JiKuch
                        Who is interested in the IP5108 solution, so look at the implementation in the section PROJECTS:
                        M5 Power Bank with IP5108
                        • E Offline
                          elecvoice @vshymanskyy
                          @vshymanskyy
                          IP5306 https://yadi.sk/i/dRp0HTF4oPCo2g
                          Same thing for IP5209 IP5109 IP5207 IP5108
                          https://yadi.sk/i/oNhqTei36jFwSg
                          • E Offline
                            @vshymanskyy Did you scann old chip (IP5306) or new version (IP5306_I2C). Can it be possible, that old version can I2C too?
                              forelnyr
                              @vshymanskyy please, could you send schematic of IP56306 I2C connection? I try to connect to my (which should have I2C) - but she doesn't reply. I use external microcontroller with external supply. Also I connect SCL to 2nd and SDA to 3st pin pin of IP5306. IP5306 powered from li-ion battery.
