    UNITCAM Problem
    21 Posts 5 Posters 48.5k Views 1 Watching
      plusulli
      it is not possible to get a token
      • N Offline
        nigauriko @m5stack
        @m5stack I have the same problem. I downloaded sample blocks for the UnitCam + M5Stack from the UIFlow. These look the same blocks as used in your video in the product page. When I push Button-A, the blue LED on UnitCam flashes twice, but nothing happens if the Button-B is pushed. I am not familiar with “M5 cloud”, but how can I make sure if the captured images are uploaded the right place? That would be great if you could share with us how the sample program works as well.
          ksprayberry
          I am using the example code straight out of UIflow and only adding my SSID and password , but I get no qrcode.
          • m5stackM Online
            1. check your device's connection is not a problem.
            2. if using the UART mode is works, you should check to enter SSID and password are right. (don't include any special char)
            3. which UIFlow firmware version are you used? after you run the program. did you get any errors?
            K N 4 Replies Last reply Reply Quote 0
              plusulli
              I believe you that it works on your intranet but I live in Germany and it doesn't work there.
              To your questions
              1. my device has no problem
              2. my SSID and password are correct and there are no special characters in them.
              3. why the question about the UIFlow version when it should only be possible with version V1.7.8?
                ksprayberry @m5stack
                @m5stack Same here. I have checked and double checked my SSID and password. The uart works and I can see the picture on the display. I am using 1.7.8 on both the UIflow and the Grey Core. I do not see any errors, but I can't help but thinking it is freezing up. Sometimes it will display pictures by a frame every 5 seconds, but sometimes it does not. But more than anything it does not seem to be retrieving the qrcode.
                  @m5stack Ok, I finally got it to generate a qrcode. Maybe what the issue is, is that it takes an inordinate amount of time to generate the qrcode. It does not immediately generate the code. It seems to take about 3-5 minutes to generate the code. I was thinking it was maybe instantaneous. Maybe that is the issue with others too. The issue I am having now is that I do not see an image. I see the image using UART, but I'm not seeing it on the web address.
                    @m5stack Sorry for the multiple replies. An update. I moved the core and camera very close to the router and it immediately connected and produced a qrcode and I am able to see the pictures.
                      plusulli
                      also with me it works now without that I have changed something
                      • N Offline
                        nigauriko @m5stack
                        @m5stack I don't know why but it finally worked after several runs from the UIFlow. I didn't change anything, but it seems to be quite sensitive to the WiFi connectivity. Now I can see interval images on the camera.m5stack.com/timer-cam/...
                        • m5stackM Online
                          m5stack @nigauriko
                          @nigauriko maybe is the wifi signal quality not good?
                            ksprayberry
                            Just wanted to check in and see if anyone's UNIT CAM is working with the current version of UIFlow. I'm beginning to think I've killed mine somehow. I can't get it to work in UART or WIFI mode either one, I've tried it with a couple of Cores and nothing works.
                            Thanks!
                            Kelly
                            • I Offline
                              ikutomo @m5stack
                              @m5stack I'm having this same problem. I think it is probably caused by a slow Wi-Fi throughput issue with UnitCam.
                              A solution to this problem has been found by Sohtamei in the following thread;
                              https://community.m5stack.com/topic/3649/unitcam-hw-issue-cannot-stream-video/8
                              On the UnitCam, set the WROOM-32 clock to XCLK=8MHz and the ov2640 clock to twice the current clock.
                              Could you please reflect this solution in the UnitCamForUIFlow firmware?
                              • I Offline
                                ikutomo
                                @m5stack
                                Could you please correct the UnitCamForUIFlow firmware as follows?
                                Set the WROOM-32 clock to XCLK=8MHz and the ov2640 clock to twice the current clock.
                                This solution has been found by Sohtamei in the following thread;
                                Thanks a lot.
