    89 Posts 25 Posters 438.9k Views 10 Watching
    • G Offline
      gipsyblues @m5er
      @m5er could you please clarify how to and where to download your version of the crypto ticker to try? M5Burner does not lead anywhere
      TIA
      • G Offline
        gipsyblues
        Anyone knows how to to obtain TicrThing version of the ticker for test?
          Albman
          Hi, the M5Stack stand https://shop.m5stack.com/products/btc-standing-base?variant=16804779229274 has an DHT12 sensor for temperature and humidity integrated. I woud like to integrate this output in my BTC ticker. Any hints how to do this? Or where to start? I have not much experience with M5Stack or programming at all...
          • frittnaF Offline
            frittna
            Here you go! I coded some lines. Try this from there: https://github.com/frittna/Crypto_Coin_Ticker
            just download the M5Burner zip packet, extract it to a path with no spaces in name (causes errors!) run M5burner.exe and select COM + BAUD + Crypto_Coin_Ticker_Sensor_Cel.ino or the Fah version for Fahrenheit and give it a try.
            BTW: it is a SHT30 Senor built in my base, not a DHT12 although it is written in the description. The temperature is pretty high since the sensor is getting heat from the device itself i guess, maybe a problem of many small devices with temp sensors built in.
            *** For regular users without the vertical base i recommend to use the normal version because i had to make the info panel a bit larger and loose candle chart hight. **
            edit: I fixed a bug that the user settings were not saved after a restart - reflash from github if you are affected.
              m5er @gipsyblues
              @gipsyblues I suppose you have figured it out by now (and sorry for late reply - I got no notification for this post). In any case, you can download the M5Burner software, connect your M5stack basic (not core2) and flash the TicrThing firmware. Let me know if you encounter difficulties, preferably in a PM so we don't hijack this thread.
                Albman @frittna
                @frittna You da man! Haven't had the time to have a look back here, so my late reply. Works like a dream! I see also the offset with the temp but it doesn't bother me so much. Maybe the offset could be dealed with by manually giving a correction factor at startup?
                So thank you very much, I am deeply impressed like only a layman (in coding) can be :-)
                  PiriX
                  I have followed the instructions step by step in my M5Stack ESP-32 and that's what I get:
                  Can anyone help me with the mistakes?
                  Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                  WARNING: library Timezone claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
                  File "esptool.py", line 57, in <module>
                  File "/Library/Python/2.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 389, in load_module
                  File "serial/tools/list_ports.py", line 29, in <module>
                  File "serial/tools/list_ports_posix.py", line 31, in <module>
                  File "serial/tools/list_ports_osx.py", line 32, in <module>
                  Failed to execute script esptool
                  Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD
                  Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
                  Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
                  Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
                  exit status 255
                  /Applications/Arduino.app/Contents/Java/arduino-builder returned 255
                  • frittnaF Offline
                    frittna @PiriX
                    @pirix
                    i have not set up an enviroment for compiling in osx yet, i can't say.. sorry
                    @Albman THX! , yea maybe i'll implement a temperature correction some day
                      PiriX @frittna
                      @frittna I tried with M5Burner in Windows and compiling it on Ubuntu with the same problem: freezes trying to connect to Wi-Fi.
                      Any option?
                      • frittnaF Offline
                        frittna @PiriX
                        @PiriX
                        when you say you burned it with the burner than it should work. I only think of a sd config file corruption or something because of not safe ejected.. or some strange letters in wifi-pass.. i dunno..
                          PiriX
                          @frittna said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
                          I tested with my guest wifi: "guest" pass "guest" and doesn't work
                            PiriX
                            Now it works...
                            The problem was "_" in the Wi-Fi
                            Thank you so much for your patience.
                              kaos
                              Hi frittna,
                              Awersome work for making this for us, its a struggle to keep watch of the crypto market while also living a life away from it.
                              I'm a noob, but i'm sure if I know exactly where to edit, i could get away with it, so my query is how do edit one of the existing
                              timezones to get my local timezone option? I'm looking for GMT +8 (Singapore/Kuala Lumpur Timezone). Thanks is advance!
                              • frittnaF Offline
                                frittna
                                Hi and thank you very much. Yea, it's really a good alternative to a pc running all day or checking your mobile all the time. You can focus on other things and have always an eye on it. It's nice to have one under your pc screen btw.
                                to your question, the corresponding part is the following. You would have to add for example your Zimezone as nr.8 in the code and compile it new in Arduino, then set the same number in the sd-config to load this setting at least once. If you're really new to arduino its a bit tricky with all the libraries and stuff (boardmanager!) but it is documented.
                                Problem right now is that i dont know where to find the correct TimeChangeRule values for your timezone (UTC+8 is SGT ...?)
                                Maybe you find some info. I found the lines i used in the code on the web or in Arduino code examples but i know no more zones right now.
                                here is the part at the beginning
                                TimeChangeRule summer_aedt = {"AEDT", First, Sun, Oct, 2, 660}; // 0: Australia Eastern Time Zone (Sydney, Melbourne)
                                TimeChangeRule standard_aest = {"AEST", First, Sun, Apr, 3, 600};
                                TimeChangeRule summer_bst = {"BST", Last, Sun, Mar, 1, 60}; // 1: United Kingdom (London, Belfast)
                                TimeChangeRule standard_gmt = {"GMT", Last, Sun, Oct, 2, 0};
                                TimeChangeRule summer_eest = {"EEST", Last, Sun, Mar, 3, 180}; // 2: Eastern European Time (Bulgaria, Greece, Romania, Ukraine, Egypt)
                                TimeChangeRule standard_eet = {"EET ", Last, Sun, Oct, 4, 120};
                                TimeChangeRule summer_cest = {"CEST", Last, Sun, Mar, 2, 120}; // 3: Central European Time Zone (Frankfurt, Paris)
                                TimeChangeRule standard_cet = {"CET ", Last, Sun, Oct, 3, 60};
                                TimeChangeRule summer_edt = {"EDT", Second, Sun, Mar, 2, -240}; // 4: US Eastern Time Zone (New York, Detroit)
                                TimeChangeRule standard_est = {"EST", First, Sun, Nov, 2, -300};
                                TimeChangeRule summer_cdt = {"CDT", Second, dowSunday, Mar, 2, -300}; // 5: US Central Time Zone (Chicago, Houston)
                                TimeChangeRule standard_cst = {"CST", First, dowSunday, Nov, 2, -360};
                                TimeChangeRule summer_mdt = {"MDT", Second, dowSunday, Mar, 2, -360}; // 6: US Mountain Time Zone (Denver, Salt Lake City)
                                TimeChangeRule standard_mst = {"MST", First, dowSunday, Nov, 2, -420};
                                TimeChangeRule summer_pdt = {"PDT", Second, dowSunday, Mar, 2, -420}; // 7: US Pacific Time Zone (Las Vegas, Los Angeles);
                                TimeChangeRule standard_pst = {"PST", First, dowSunday, Nov, 2, -480};
                                Timezone myTZ0(summer_aedt, standard_aest); // myTZ0: 0 Australia Eastern Time Zone (Sydney, Melbourne)
                                Timezone myTZ1(summer_bst, standard_gmt); // myTZ1: 1 United Kingdom (London, Belfast)
                                Timezone myTZ2(summer_eest, standard_eet); // myTZ2: 2 Eastern European Time (Bulgaria, Greece, Romania, Ukraine, Egypt)
                                Timezone myTZ3(summer_cest, standard_cet); // myTZ3: 3 Central European Time Zone (Frankfurt, Paris)
                                Timezone myTZ4(summer_edt, standard_est); // myTZ4: 4 US Eastern Time Zone (New York, Detroit)
                                Timezone myTZ5(summer_cdt, standard_cst); // myTZ5: 5 US Central Time Zone (Chicago, Houston)
                                Timezone myTZ6(summer_mdt, standard_mst); // myTZ6: 6 US Mountain Time Zone (Denver, Salt Lake City)
                                Timezone myTZ7(summer_pdt, standard_pst); // myTZ7: 7 US Pacific Time Zone (Las Vegas, Los Angeles);
                                and later in the code:
                                ..} else if..=4..
                                ..} else if..=5..
                                } else if (myTimeZone == 6) {
                                time_t now = myTZ6.toLocal(time(nullptr), &tcr);
                                M5.Lcd.printf("%s %2d.%s %02d:%02d", weekDay_MyLang[weekday(now)], day(now), monthName_MyLang[month(now)], hour(now), minute(now));
                                } else if (myTimeZone == 7) {
                                time_t now = myTZ7.toLocal(time(nullptr), &tcr);
                                here the new else if for nr.8
                                i think that would be all
                                  kaos
                                  Thanks Frittna, yes my timezone is UTC +8, and I think I have found a reference on how to set that <see below> ; my timezone dont have DST, so it should just a simple one liner (i think), still not tested though..cuz ya, i'm a newbie, so about that compiling, could you point me exactly where to look? :)
                                  My M5stack is the FIRE version ; with the LED bars , and this is my first project using it (actually got inspired to get it after seeing your project, as I was wanting a proper tabletop ticker for some time now), will there be any version that can utilize those LEDs as indicators, that would be awesome!
                                  For a time zone that does not change to daylight/summer time, pass the same rule
                                  twice to the constructor, e.g.:
                                  Timezone usAZ(usMST, usMST);
                                  In fact the WorldClock example does this for Arizona:
                                  //US Mountain Time Zone (Denver, Salt Lake City)
                                  TimeChangeRule usMDT = {"MDT", Second, dowSunday, Mar, 2, -360};
                                  TimeChangeRule usMST = {"MST", First, dowSunday, Nov, 2, -420};
                                  Timezone usMT(usMDT, usMST);
                                  //Arizona is US Mountain Time Zone but does not use DST
                                  So mine should be >>>
                                  //for Malaysia its MYT (UTC+8)Time Zone but does not have DST
                                  Timezone MYT(MYT, MYT);
                                  • frittnaF Offline
                                    frittna
                                    Updated Version (minor changings):
                                    • added cycling function: enable/disable by pressing ButtonA+ButtonC together. steps through your currencies after a certain time (default: 15sec for each currency)
                                    • added Timezone for Singapore (UTC+8)
                                    • code merged to one version, so there is no need to have different versions anymore
                                    • autodetect the optional room sensor and show 12pixel high sensor panel in this case temperature unit C or F and offset is set from SD-Config and not hardcoded anymore (because the M5-Stack is heating up itself it will never be accurate and has only limited expressiveness)
                                    last modified Nov.20.2021 15:20 CET - Version 1.0.53fix
                                    -> https://github.com/frittna/Crypto_Coin_Ticker/
                                      Reddai
                                      I'm getting crazy. I have a SSID with spaces: I Installed it for the first time around the end of October. I updated it with the cycling function. it connected flawlessy. Yesterday I wanted to add a new pair, and now it does not connect anymore to wifi ... that's weird
                                      • frittnaF Offline
                                        frittna @Reddai
                                        @reddai
                                        hard to predict but i experienced odd behavior with reading settings when i for example forgot to eject the sd-card on pc by control center (use checkdisk on the sd card too if you forgot).
                                        Or maybe you have some hidden symbols from a copy paste action in your settings file or router config page. I'm not so good with ascii code but like when you see a url link with %20 for space or something. Maybe you used a complex texteditor? use simple text editor, no format options, and of course check every single sign... frustrating to not know. First i would try a fresh config file and only wifi settings. Before check your SD card. When this still fails try without space in name, if it works we have to accept that fact or better investigate that "space in name" problem of the used esp32 library
                                          Reddai @frittna
                                          @frittna thanks for your help ! I did a fresh config with a formatted sd completly empty and it worked!!
                                          • Y Offline
                                            yashax
                                            Is there a way to use this code on Core2?
