Simple fix when upload fails.
I am getting errors when trying to up load, it sees the board but gives he following errors:
Arduino: 1.8.1 (Windows 7), Board: "M5Stack-Core-ESP32, QIO, 80MHz, 115200, None"Sketch uses 351999 bytes (26%) of program storage space. Maximum is 1310720 bytes.
Global variables use 12024 bytes (4%) of dynamic memory, leaving 282888 bytes for local variables. Maximum is 294912 bytes.
esptool.py v2.1
File "esptool.py", line 2524, in <module>
File "esptool.py", line 2517, in main
File "esptool.py", line 2246, in main
File "esptool.py", line 177, in init
File "site-packages\serial_init.py", line 88, in serial_for_url
File "site-packages\serial\serialwin32.py", line 62, in open
serial.serialutil.SerialException: could not open port 'COM6': WindowsError(23, 'Data error (cyclic redundancy check).')
Failed to execute script esptool
the selected serial port Failed to execute script esptool
does not exist or your board is not connectedThis report would have more information with
I updated the Arduino IDE to 1.8.5 Installed the usb drivers, it still doesn'y work. When the M5 is plugged in it shows up in the device manager and the port is working correctly. so I know the usb port is good. I also tried lowering the transfer sped as suggested and that doesn't help. I will try to find a capacitor some where. It is kind of disappointing that with all the work that went into this it has problems connecting.
I tried the cap, here is a screen shot of whats the problem. The pc is seeing the port, it recognises the driver and is working.
It is trying to upload, but times out I tried both baud rates neither works.![alt text]( image url)
I tried reversing the cap, It still won't connect. It still has the same timeout problem. Changing baud rate doesn't help either.
I am using win7 and arduino ide 1.8.5. The board automatically selects the com port when plugged in . The port varies .
I have the cap soldered onto dupont leads and have them plugged all the way in. I tried both polarity'sI keep getting the "timed out waiting for packet header " error. for whatever reason it won't connect. I have no problems with the ports with various Arduino boards, ESP8266's and ESP32's
@stanszal 在 Simple fix when upload fails. 中说:
As a note, I am having the exact same problem. I'm using PlatformIO, but the esptool output is the same indicating the same underlying error.
When I look at the Serial Monitor, it's booted and here is the output:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:812
load:0x40078000,len:0
load:0x40078000,len:11404
entry 0x40078aa0
user code doneI recovered mine using the EspressIF ESP32 Download Tool following the M5 guide for loading their MicroPython / Cloud IDE firmware.
I wanted to play around with their cloud IDE anyway, but you should be able to use the factory firmware (also on GitHub) or one of the ones in your Arduino compile cache that you know works.
Edit: Forgot to mention, I did have to use a 10uf cap across the GND and RST pins as described earlier in the thread in order to get the EspressIf tool to be able to connect.
After much fiddling around I managed to connect to it. However it is unreliable. This thing is a big disapointment. It is obvious a lot of work went into this thing, but they should have put in a little more to get it to work right out of the box.
You can get Various Arduinos, ESP8266's and ESP32's for much less and they just work.
so sorry, pls try this.
try what? add a cap? what type and volts? where can I get 1 cap? how about I send this back and you fix it so it works?
Here is how I see it, I already spent over $40.00 for this thing. Yes, I can spend another $3.50 and order some caps, wait 5 to 6 weeks for them to arrive and they may or may not solve the problem. If this is a known issue you should have included a cap with the device.
I tried 3 caps, 2 electrolitica and a polyester one. the result is the same, you need to try to upload the sketch multiple times to maybe get it to work once.
JimiT and ElectroMagnus, thank you for your help
Hey @Stanszal ... I just got one of these and had issues with getting the uploading working. I found that if I reset the device and got the timing right then it would work. You just reset it while the "...____" message is writing. I can't tell you when to do it specifically, you just have to guess.
Mine worked great until today. I really don't understand why it stopped working today.
