    PROJECTS
    22
    95
    684.0k
    • RopR
      Rop @janseta
      @janseta I am loosely thinking about adding:
      • NTP time and also an inactivity power-off
      • A settings menu with
        • link to the wifi menu
        • NTP on/off, which server(s) and sync interval
          • clock display in header on/off
        • display backlight brightness
        • FACES keyboard support on/off
        • Setting up the M5Stack peripherals (which GPIOs etc)
      But everything I add adds code size. So there probably there will be a few more code blocks like the present #ifndef M5EZ_WITHOUT_WIFI to allow people to not compile what they do not need.
      But before I get to this I need to figure out why the .setTimeout method does not seem to affect the https transfers for the firmware because they timeout way too often.
      Everyone: please feel free to suggest new features or tell me what you think about the proposed ones above.
      • B
        bobolink @Rop
        @rop Finally got around to trying the image converter script--works great. Thanks again.
        I have a windows 7 machine for HexWorkshop but ...
        I need to center the image I'm using but I should be able to figure that out.
        Also, new a version of your library showed up in the Arduino-IDE library check! Automagically.
        • RopR
          Rop @bobolink
          @bobolink As to centering the images: I can put it anywhere, but have no easy way (that is without linking in a ton of code) to figure out how high or how wide a jpg is. I could provide an image offset in x and y, but that would probably make most sense if it was settable per image. You could always just center them in Photoshop / Gimp / etc...
          • B
            BTMp
            Hi @Rop
            I wonder if you could help me.
            I am really looking forward to using M5ez but unfortunately I'm having problems compiling the examples and I'm getting persistent errors relating to any instance of println
            This is a snippet of the error messages
            Arduino: 1.8.5 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Minimal SPIFFS (Large APPS with OTA), 921600, Debug"
            In file included from /Users//Documents/Arduino/libraries/M5ez/examples/M5ez-demo/M5ez-demo.ino:2:0:
            /Users/
            /Documents/Arduino/libraries/M5ez/src/M5ez.h:42:27: error: 'TFT_TRANSPARENT' was not declared in this scope
            #define PRINT_DEFAULT_COL TFT_TRANSPARENT
            /Users//Documents/Arduino/libraries/M5ez/src/M5ez.h:117:104: note: in expansion of macro 'PRINT_DEFAULT_COL'
            void print(String text, int16_t x = -1, int16_t y = -1, const GFXfont* font = NULL, uint16_t color = PRINT_DEFAULT_COL);
            /Users/
            /Users//Documents/Arduino/libraries/M5ez/src/M5ez.h:118:106: note: in expansion of macro 'PRINT_DEFAULT_COL'
            void println(String text, int16_t x = -1, int16_t y = -1, const GFXfont* font = NULL, uint16_t color = PRINT_DEFAULT_COL);
            /Users/
            /Documents/Arduino/libraries/M5ez/examples/M5ez-demo/M5ez-demo.ino: In function 'void submenu_more()':
            M5ez-demo:51: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("");
            M5ez-demo:52: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("ezMenu menu("Main menu");");
            M5ez-demo:53: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("menu.addItem("Option 1");");
            M5ez-demo:54: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("menu.addItem("Option 2");");
            M5ez-demo:55: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("menu.addItem("Option 3");");
            M5ez-demo:56: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println("while ( menu.run() ) {");
            M5ez-demo:57: error: call to 'void M5ez::println(String, int16_t, int16_t, const GFXfont*, uint16_t)' uses the default argument for parameter 5, which is not yet defined
            ez.println(" if (menu.pick == 1) {");
            <<<<AND SO ON WITH THE OTHER PRINTLN CALLS >>>>>>
            Looks like I'm missing something from my environment but any ideas?
            Many thanks
            • RopR
              Rop
              @btmp 在 M5ez, a complete interface builder system for the M5Stack as an Arduino library. Extremely easy to use. 中说:
              That is the problem here. Strange...
              With me that #define comes with the M5Stack library, as part of the display driver, in the file .../Arduino/libraries/m5stack/src/utility/In_eSPI.h on line 373. I have version 0.2.2 of that library.
              • B
                BTMp
                So....that file wasn't actually there on my system.
                A lesson in keeping up to date for me there.
                All compiles now.
                Really nice piece of work, especially like the OTA update functionality.
                Thanks for the help.
                • J
                  janseta
                  @rop
                  Hi Rop,
                  I see you worked hard with the clock in ezTime library...
                  I wonder what will be the next step...
                  Will you merge M5ez with ezTime?
                  Will they be independent works?
                  Will M5ez call the functions of ezTime?
                  ¯_('-')_/¯
                  • RopR
                    Rop @janseta
                    @janseta If you have ezTime and turn on the clock (it'll be a #define), M5ez will use ezTime to show an on-screen clock. And naturally if you include it in your own sketch you can use the features of it in your own code as well. Soon...
                    • RopR
                      Rop
                      Hi everyone,
                      I just released version 1.3.1 of M5ez: it can now use images from program flash, SD-card and SPIFFS in image menus.The documentation says how, and there's an example that shows it in action.
                      • R
                        r_255
                        Hi Rop,
                        I finaly found some time and as non programmer i did manage to use your code and make it talk mqtt just copy and pasted some code from you and the pubsub lib and it does work.
                        Below the code i used to control my domoticz setup thru mqtt :
                        I had to make some adjustment to PubSubClient.h and made some values higher like socket timeout, max packet size and degraded version.
                        So i guess it isnt that hard after all. To make sure you understand that i am a compete noob and dont even know what language i have been copy and pasting.
                        Next try will be to use the ezProgressBar and let that drive the dimmer based on pb.value. But that will be a real challenge for me as copy and paste coder.
                        adjustment to PubSubClient.h:
                        #define MQTT_SOCKET_TIMEOUT 60
                        #define MQTT_MAX_PACKET_SIZE 1024
                        #define MQTT_VERSION_3_1 3
                        Now the code below runs fine sofar ( 15 mins or so )
                        #include <M5Stack.h>
                        #include <M5ez.h>
                        #include <WiFi.h>
                        #include <PubSubClient.h>
                        const char* ssid = "xxxxxx";
                        const char* password = "xxxxxxxxxxx";
                        const char* mqttServer = "xxxxxxxxxxxxxx";
                        const int mqttPort = 1883;
                        const char* mqttUser = "xxxxxxxxxxxxxxxxt";
                        const char* mqttPassword = "xxxxxxxxxxxxxx";
                        WiFiClient esp32Client;
                        PubSubClient client(esp32Client);
                        long lastMsg = 0;
                        char msg[50];
                        int value = 0;
                        Serial.begin(115200);
                        WiFi.begin(ssid, password);
                            delay(500);
                            Serial.println("Connecting to WiFi..");
                        Serial.println("Connected to the WiFi network");
                        client.setServer(mqttServer, mqttPort);
                          while (!client.connected()) {
                            Serial.println("Connecting to MQTT...");
                            if (client.connect("esp32Client", mqttUser, mqttPassword )) {
                              Serial.println("connected");
                            } else {
                              Serial.print("failed with state ");
                              Serial.print(client.state());
                              delay(2000);
                          m5.begin();
                          ezMenu myMenu("Main menu");
                          myMenu.addItem("lamp bank aan", mainmenu_one);
                          myMenu.addItem("lampbank uit", mainmenu_two);
                          myMenu.addItem("dimmer keukenlamp", mainmenu_three);
                          myMenu.run();
                        void mainmenu_one() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 136, \"switchcmd\": \"On\", \"level\": 100}");
                          Serial.println("mqtt send");
                        void mainmenu_two() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 136, \"switchcmd\": \"Off\", \"level\": 0}");
                          Serial.println("mqtt off send");
                        void mainmenu_three() {
                          ezMenu subMenu("Submenu");
                          subMenu.addItem("Keuken off", submenu_off);
                          subMenu.addItem("Dim 10%", submenu_one);
                          subMenu.addItem("Dim 20% ", submenu_two);
                          subMenu.addItem("Dim 30%", submenu_three);
                          subMenu.addItem("Dim 40%", submenu_four);
                          subMenu.addItem("Dim 50%", submenu_five);
                          subMenu.addItem("Dim 60%", submenu_six);
                          subMenu.addItem("Dim 70%", submenu_seven);
                          subMenu.addItem("Dim 80%", submenu_eight);
                          subMenu.addItem("Dim 90%", submenu_nine);
                          subMenu.addItem("Dim 100%", submenu_ten);
                          subMenu.addItem("Back | Back to main menu");
                          subMenu.upOnFirst("last|up");
                          subMenu.downOnLast("first|down");
                          subMenu.run();
                          client.loop();
                        void submenu_one() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 10}");
                        void submenu_two() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 20}");
                        void submenu_three() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 30}");
                        void submenu_four() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 40}");
                        void submenu_five() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 50}");
                        void submenu_six() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 60}");
                        void submenu_seven() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 70}");
                        void submenu_eight() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 80}");
                        void submenu_nine() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 90}");
                        void submenu_ten() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\": 100}");
                        void submenu_off() {
                          client.publish("domoticz/in", "{\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Off\", \"level\": 0}");
                        • B
                          bobolink @Rop
                          @rop
                          I’m completing my first project using M5ez/M5stack. A remote control.
                          I would like to indicate two things on a menu, the current state of the remote equipment and the next state (that will become the current state when the “select” button is pressed and a ESP-Now message is sent/acknowledged).
                          The next state is your select item black cursor line with reverse text but people might think that is the current state of the remote equipment—if they forget to press “select”. I could automatically send the message after dwelling on a selection after a few seconds like a tv remote. But I’d like to make them explicitly press “select” with this remote equipment.
                          I now indicate current state by putting it as the first item on the menu and using bold text but a green check mark ✅ or dot ⚫️ would be more assertive. Unless I’m overlooking a better method.
                          Thanks again for M5ez.
                          @bobolink
                          • R
                            r_255
                            I am failing hard on the progressbar, is there any other pointer or example people could share.
                            I have been reading for a few days, but i just dont get it.
                            I am not sure about pb.value(float val)
                            i want to add or distract 10 on a button push, but i am failing hard.
                                      if (btnpressed == "up")
                                      break;
                                      else (btnpressed == "left"); {
                                      pb = pb + 10; ;
                                      if (btnpressed == "right"); {
                                      pb = pb + 10;
                            Would be nice to abuse the progressbar for things like volume or dimmer status and if any one has a pointer. thanks in advance.
                            • B
                              bobolink @bobolink
                              @Rop
                              Ouch!
                              I forgot M5EZ blocks!
                              Doesn’t lend itself to a controller at all.
                              Starting over.
                              • R
                                r_255
                                Okay i can get some value in to pb now and raise it once with + 10 by pushing a button and then i stall.
                                void add(){
                                      ezProgressBar pb ("Dimmer", "Dims te kitchen light", "LEFT#UP#RIGHT");
                                       pb.value(val);
                                  while (val <= 101 && val >= 1 ) {
                                        String btnpressed = ez.getButtons();
                                    if (btnpressed == "UP") loop();
                                    if (btnpressed == "LEFT") {
                                        pb.value(val - 10);}
                                    if (btnpressed == "RIGHT") {
                                        pb.value(val + 10);
                                but i am not giving in until i got this running.
                                Any one that can give this noob some pointers ? It doesn't have to be a fixed solution but after some days of learning i am kind of blinded
                                • RopR
                                  Rop @r_255
                                  @r_255 Whoops... I just noticed yesterday that progressBar is broken in that it can only go up, not down. Expect a fix with the all new M5ez 2.0, out as soon as I am done. (It's 85% there, a few days more...)
                                  2.0 will also have backlight setting, a clock in the header bar as well as definable header widgets and the ability to register functions to be part of M5ez's idle loop.
                                  • R
                                    r_255
                                    Thats good to know, so it could be that it isnt me... Learned a lot the past days! Thanks
                                    Still have some issues on loosing connection over time, but not sure if that is me or the m5stack. Am i the only one ?
                                    PS: backlight dimming would be nice on a ProgressBar, if it isnt to much work.
                                    • B
                                      bobolink @bobolink
                                      @bobolink
                                      I solved the blocking issue by putting the UI on one core and the communications (esp-now) on the other.
                                      • R
                                        r_255
                                        Thanks bobolink, i will find some lessons about using the 2 cores of the esp32.
                                        Cheers!
                                        • B
                                          bobolink @r_255
                                          @r_255
                                          Good luck. I’ll try to post a skeleton example somewhere. But you might start here:
                                          YouTube
                                          Research a mutex for sharing data between processes.
                                          Also, @Rop says he is adding registration of functions to execute from his idle loop.
                                          I think M5Stack and M5ez have a great future in remote control of all sorts of things. Using the WiFi radio, IR, BLE, UART, etc.
                                          • R
                                            r_255
                                            @bobolink
                                            yeah, i did find the guy with the funny accent ;o) video including the skeleton file.. thanks for the link!
                                            I totaly agree! It might not be made with the intention to be remote controller, but it could be a nice one.
                                            Not sure about battery life, but there is still much to gain on that subject i guess. Screen brightness for instance will help a lot.
                                            I guess there are also a lot of things you could hook up on to the slider
                                            Like a dimmer, volume controller or even stuff like tv channels, Where a double press could be 10 up or 10 channels down. where a short press is just one.
                                            Or in a horizontal menu indicating where you are.
                                            Not sure if the ezslider bar could be re positioned or combined with a image, but i guess we will find a way.....
                                            Still wondering how i could do a rgb device in a easy way besides giving every color its own page.
                                            :O)
