    cant flash latest m5 stamp c3
    ESP - IDF
    21
    64.8k
    • H
      HaSch @felmue
      @felmue said in cant flash latest m5 stamp c3:
      I've just tried flashing my M5StampC3 through its built-in USB. Worked like a charm.
      I have no chance to flash any file:
      esptool.py v3.1
      Serial port /dev/cu.usbmodem53220362951
      Connecting....
      Chip is unknown ESP32-C3 (revision 3)
      Features: Wi-Fi
      Crystal is 40MHz
      MAC: 34:b4:72:12:9b:ac
      Uploading stub...
      A fatal error occurred: Failed to write to target RAM (result was 01070000)
      Is there a usb driver missing? How to get and install?
      BR,
      Hans
        Hello @HaSch
        sorry, I don't know if you're missing a driver or not. On Ubuntu 20.04 there was no need to install a driver. Whatever is required seems to already be included in the stock version of Ubuntu 20.04.
        I was wondering, in your case it fails while 'Uploading stub' which as I understand is not necessarily needed. In menuconfig there is an option Serial flasher config - Disable download stub which by default is unchecked. Maybe try to disable the downloading of the stub and see if that gets you any further.
        BTW: what operation system and version are you using? Window? MacOS?
        • H
          HaSch @felmue
          I'm sorry, I'm using Arduino IDE and there is no menuconfig. But I have "USB CDC On Boot". Should it be enable or disable? I'm on a Mac with MacOS 10.15.7 Catalina.
            Hello @HaSch
            well, disabling downloading the stub doesn't help anyway - so my idea is moot. I've just setup a machine with macOS Big Sur 11.5.2 and with or w/o downloading the stub the download process ends in an timeout error.
            What worked for me on macOS Big Sur 11.5.2 however is using the ESP32C3 built-in USB via GPIO18 and GPIO19.
            • H
              HaSch @felmue
              Hello @HaSch
              It really seems to be an issue with USB serial driver. I also tried to download and install the CH9102_VCP_SER_MacOS driver from here without success. Trying to install to my MacOS 10.15.7 Catalina ends up with an error:
              安装提示
              sysex didFailWithError The operation couldn’t be completed. (OSSystemExtensionErrorDomain error 9.)
              • H
                HaSch
                I urgently need a working driver for m5stamp c3 for MacOS 10.15.7 Catalina. I tried to get it work via GPIO18 and GPIO19 but don't know how because there is no driver for that on my system. Using USB-C ist throwing the known error because of the wrong or incomplete driver. Even downloading and installing the suggested driver didn't solve the problem.
                  Hello @HaSch
                  sorry, I cannot help you with macOS 10.15.7 Catalina. I don't own any Apple hardware recent enough to run that version of macOS. Do you have access to another computer?
                    ajb2k3 @HaSch
                    @hasch said in cant flash latest m5 stamp c3:
                    Catalina is bugged since Apple released the OSX update, you need a full OSX update to 10.16 or try another TTL USB to UART adapter.
                    • H
                      HaSch @ajb2k3
                      @ajb2k3 said in cant flash latest m5 stamp c3:
                      It's the built in adapter of M5Stamp C3!
                        Hello @ajb2k3
                        As an experiment I've tried to use another TTL USB UART adapter as you suggested, but it did not work. I suspect the adapter built into the C3 is interfering with some data lines.
                        Did you have success with another TTL USB UART adapter? If yes, how did you wire it?
                        • H
                          HaSch
                          I FOUND THE SOLUTION!!!
                          After diving into deep of operating system I figured out a possible solution which worked for me:
                          1. I had a usbserial.kext laying in /Library/Extensions/ and I figured out that it was also a WCH driver
                          2. I deleted usbserial.kext and restarted the Mac again => no success
                          3. I deleted CH34xVCPControlDriver.kext and CH34xVCPDriver.kext in /Library/Extensions/ and restarted again
                          4. I installed another driver: FTDIUSBSerialDextInstaller_1_4_7 and had to confirm SIP integrity
                          5. In system preferences -> security I had to enable access for the FTDI driver and saw another process pending named something with Quinheng
                          6. As I remembered that Quinheng has something to do with WCH I ticked this process too and restarted
                          7. I installed CH34xVCPDriver.pkg V1.7 again and restarted => no success
                          8. I plugged in a CH340G device and suddenly a /dev/cu.wchusbserialXXX port appears in my Arduino IDE and is working with my CH9102 device
                          9. Plugging out CH340G device continues /dev/cu.wchusbserialXXX working
                          Hope that this solution will work for other people too!
