    UIFLOW 1.9.1 NO LONGER UPLOADING FIRMWARE URGENT!!!!!!
    Core 2
    7
    15
    19.8k
      Hello @lmartu68
      UIFlow doesn't load for me at all anymore - I get just an empty white window. From the browser debug screen it looks like some Javascript resources can not longer load / been found.
      L T 2 Replies Last reply Reply Quote 0
      • L
        lmartu68 @felmue
        @felmue thank you Felix, no longer necessary to reply to other message I sent you.
        Let's see what happens.
        Probably a backend issue.
        L.
        • T
          tgeddings @felmue
          I have had this same problem all day.
          • L
            lmartu68 @tgeddings
            @tgeddings
            Ok , that’s not good news,
            I’ve tried using Thonny to upload python code over usb generated by uiflow, but it’s a bit clunky and hit and miss.
            When it does work I can’t get the program to persist between reboots.
            Is there no way to open a trouble ticket with the company?
            • P
              plusulli
              therefore it would be important that there should be a current Uiflow desktop
                UIFlow has been working fine for me.
                I'm using OSX 10.15.7 and chrome.
                L 1 Reply Last reply Reply Quote 1
                  Hi guys
                  probably a regional thing? Still broken for me (white screen) - even when using Chrome.
                  BTW: I've tried to upload a picture here with the browser debug output showing the partial load of some Javascript resources, but I get an error. Same backend server? Coincidence?
                  @ajb2k3 : maybe you're lucky and the Javascript resources in question are still cached on your Computer?
                  L ajb2k3A 2 Replies Last reply Reply Quote 0
                  • L
                    lmartu68 @ajb2k3
                    That’s my configuration …. Still not working
                    I get the screen and everything works in blackly except uploading code when I get an error for the web app.
                    At least the web app loads… but it is useless.
                    In which country are you?
                    • L
                      lmartu68 @felmue
                      Here’s the story
                      On my Mac I get the interface .. but it doesn’t upload , probably because it has cached elements in it, I’m sure that if I empty my browser’s cache it will show up white.
                      If I use another PC or Mac that has never connected to the UIflow site I get a white screen.
                      How can it be?
                        simmoe
                        White screen here in Denmark - no matter what browser or network
                        • ArnoA
                          Arno
                          I just tested, it works from France
                          • T
                            tgeddings
                            Yes, it is back now.
                            Tim
                              ajb2k3 @felmue
                              @felmue said in UIFLOW 1.9.1 NO LONGER UPLOADING FIRMWARE URGENT!!!!!!:
                              Hi guys
                              Possible but I have also saved a archive copy of the site to see how it works.
                                I take it from the FW 2.0 post that it could be connected to the 2.0 update
