    Stack is dead :(
    10 Posts 3 Posters 28.5k Views 1 Watching
      snmcma
      after flashing the device, the device does not turn on!
      http://forum.m5stack.com/topic/67/micropython-on-webide-1-prepare-and-hello-world
      how to revive the device?
      how to flash the device in its original state and discard the micro python?
        snmcma
        • m5stackM Online
          press the button A when reset, pls try
            snmcma
            • m5stackM Online
              you mean Arduino?
                snmcma
                @m5stack 在 Stack is dead :( 中说:
                you mean Arduino?
                Yes, Arduino
                  Kryten
                  Have you tried to reflash using sepressif flashing tool and FW that are on github?
                    snmcma @Kryten
                    @kryten
                    no, need an instruction
                      Kryten
                      http://iot-bits.com/esp32/esp32-flash-download-tool-tutorial/
                      I think you should be able to flas stock esp and run via arduino after. I have done it with esp8266
                        snmcma @snmcma
                        @snmcma 在 Stack is dead :( 中说:
                        you mean Arduino?
                        Yes, Arduino
                        can throw off the firmware file for overwriting in m5? and a screenshot how to write down
                        you can throw off all the firmware files with the instruction how to return to the initial state, micropyton does not suit me. I reprogrammed it as an esp32 dev module, unfortunately in m5stack mode it is not programmed
