    Mod to programmatically disable speaker whine/hiss.
    PRODUCTS
    8
    10
    29.5k
      Macaba
      Re: Noise on speaker
      Hi all,
      I've been working on porting the Teensy Audio Library to M5Stack to allow full (& easy) audio synthesis.
      However the background whine/hiss from the speaker when no audio is being played is very annoying (and quite loud on my M5Stack).
      My suggested modification in this case is to put a wire from Pin 1 of the speaker amplifer to GPIO5.
      Then it's just a simple case of digitalWrite(5, HIGH); to turn on the amplifier, and digitalWrite(5, LOW); to turn off the amplifier.
      There seems to be a 30-100ms delay for the amplifier to turn on, and very little delay for it to turn off so I sadly can't get my audio library to automatically turn the amplifier on/off because I would miss the beginning of any new audio playback.
      So I've just attached the amplifier control to BtnA for manual control so I can at least turn off the noise.
      Good luck to anyone else attempting this mod! :)
      C M 2 Replies Last reply Reply Quote 0
      • C
        cbrightly @Macaba
        @macaba I will have to look into this! Do you plan on sharing any of your work porting the audio libraries from the Teensy over to the M5Stack / ESP32?
          Macaba
          Yep! It'll be going on GitHub at some point.
          It won't be compatible with the the original audio objects from the Teensy library;
          1. I've moved over to float datatype for audio samples (it makes certain audio algorithms so much easier) so I've been slowly porting across the objects when I use them.
          2. I've added some functionality that lets you get more detailed CPU reporting.
          You can see my handy 'Amp on/off' control now:
            Macaba @cbrightly
            @cbrightly https://github.com/macaba/ESP32AudioLibrary
            Initial commit of ESP32/M5Stack audio library done. Not that many objects yet, I'll be adding more as time allows.
            • C
              ChrisMicro
              Hello, I just flashed it and it works. Thankx :-)
              Do you use a software sigma-delta-DAC or the internal 8 Bit DAC?
              Probably you can add a second example which shows a little bit of the sound qualities of the lib.
              • C
                Calin
                You can mute the speaker very easy from code.
                Just call
                dacWrite (25,0);
                • P
                  PlayTheGame
                  @Calin Hold your ear on the "mute" speaker. There is still noise with your code.
                  THX for the hardware mod suggestion.
                  • N
                    Nifkuzyaire
                    Maybe you can port this teensy dalek voice sketch to m5stack
                    Thank you in advance.
                    https://pastebin.com/dYf49wp5
                      masrodjie @Macaba
                      @macaba Nice. I was trying all the way to avoid noise on speaker and none of luck. Then trying using this method and it's works! Thanks
                      • F
                        funghy
                        It is probably better not to connect PIN 1 of the NS4148 but pin 3 the buck converter EA3036 to pin 5 since otherwise you have a bigger power consumption. You could also remove R23 in that case.
