    Edukit ATECC608B & AWS IOT & UiFlow
    35 Posts 4 Posters 88.3k Views 1 Watching
      ajb2k3 @ajb2k3
      >>> print(ID_0.loadTempKey(64))
      True
      >>> print(ID_0.generatePublicKey())
      True
      >>> print(ID_0.publicKey64Bytes)
      bytearray(b'\x84\xf8\xda\xf6\xda\x18&r\x1b\xf0\xdbv\x1a\xcc\xf6z\xfd\xe2>\xdcY\xd5l\xf4kk\xb7D\xffI6\x1d\xcfDO\x9f\xc8bv\x80\xa9\xb8\xe75\xc5\x13\xe4\xe91\x9b\xcelg\xeb\x01Q\x18\xd0<\x91\xcb\xd8\xc1\xa1')
      Generate and display a key!
        And a guide:
        https://www.hackster.io/AJB2K3/accessing-the-atecc608b-in-uiflow-part-1-5ac679
          Hello @ajb2k3
          thank you for putting together the guide. Unfortunately I cannot get it to work. I do not fully understand the following instructions from your guide.
          Now I have the basics after poking away at micropython I import machine and units._ID0
          import units
          from units import _ID
          ID_0 = unit.get(unit.ID, (21,22))
          Using Thonny and ...
          ... trying to import units._ID0 results in an error.
          ... where is _ID used?
          ... trying to run ID_0 = unit.get(unit.ID, (21,22)) still crashes my M5Core2.
            ajb2k3 @felmue
            @felmue It will.
            You have to run the commands in that exact order or it will crash and restart!
            If you run help('modules') in Thonny you will find the module units/_ID this took me house to work out.
            _ID0 does not exist, the module is _ID
              Hello @ajb2k3
              thank you. I appreciate all your help. Unfortunately for some reason I cannot get it to work on my side. Whatever steps I execute before, every time I try to execute ID_0 = unit.get(unit.ID, (21,22)) my M5Core2 crashes.
                ajb2k3 @felmue
                @felmue Sorry, you need to import unit
                Then import units then from units import _ID
                also the code is
                import units
                import unit
                however you can also use:
                import units
                import unit
                ATECC = unit.get(unit.ID, (21,22))
                I don't know why both unit and units (with an S) must be called but they both do.
                  Hello @ajb2k3
                  thank you again. I tried both your code sequences - still no luck. M5Core2 still reboots after the last command.
                  Which UIFlow firmware version is running on your M5Core2?
                    ajb2k3 @felmue
                    @felmue ok, its been working all day and now crashing
                    1.10.2
                    OK if you make 1 single mistake, you to to disconnect and power down the Core2 to empty the memory
                    this works.
                      Hello @ajb2k3
                      at this point I think whether the commands succeed or result in a crash depends on the amount of free memory.
                      With a freshly rebooted M5Core2 the following commands (sometimes) can be executed w/o crash.
                      >>> import unit
                      >>> print(ID_0.wakeup())
                      True
                      >>> print(ID_0.readConfigZone())
                        File "units/_ID.py", line 186, in readConfigZone
                        File "units/_ID.py", line 363, in read
                        File "units/_ID.py", line 377, in read_output
                        File "units/_ID.py", line 161, in idle_mode
                        File "i2c_bus.py", line 100, in write_list
                      OSError: I2C bus error (110)
                      True
                      >>> print(ID_0.revisionNumber)
                      bytearray(b'\x00\x00`\x03')
                      Note: The commands need to be executed manually one by one.
                      Note: I don't need the import units nor the from units import _ID commands.
                        ajb2k3 @felmue
                        @felmue said in Edukit ATECC608B & AWS IOT & UiFlow:
                        Hello @ajb2k3
                        >>> import unit
                        True
                        True
                        Agreed, once the error occurs then memory gets filled requiring hard reset.
                        You didn’t need unit or the from? I will try again later.
                        I have spent all weekend writing up the atecc for my av2 book including logging the MP modules. I’ll try without those two line tonight.
                          The issue of found was that the basic unit functions are in the unit module with unit.ID being empty but the ATecc function are all in units._ID
                            @felmue try adding the following before defining ID_0
                            From esp import gc
                            gc.collect.
                            This should help clean up some memory.
                            Nope that was wrong. the min code I can get running is
                            import unit
                            import units
                            import gc
                            gc.collect()
                            Oh cool, I got import units._ID to work.
                              @gabrielgc75 @felmue I now present to you the configuration loaded from the ATECC608b in my Core2 AWS
                                Hello @ajb2k3
                                thank you. I've tried to add the gc.collect() command. The result is still not 100% persistent. From time to time I still get a crash.
                                  ajb2k3 @felmue
                                  @felmue thanks for letting me know. It’s been stable for the testing but I’m yet to move beyond. I tried looking at provisioning for vets and codes but my brain is not taking it in hence the low level MP stuff.
                                  I’m sure there will s an issue with MP but I don’t deal directly and not getting feedback from @m5stack or @IAMLIUBO
