    Warranty question M5stack is dead
    PRODUCTS
    15
    26.1k
    • I
      ispybadguys
      I seems that the problem resolved itself. This is very strange. I removed the battery slice several times but this did not resolve the problem. I even removed it once for at least a day. Finally I removed that battery slice and I let the unit sit for several days without the battery. When I reconnected the battery it started working link nothing ever happened.
      • m5-docsM
        m5-docs @ispybadguys
        @ispybadguys A Power supply problem, please contact to Hardware Engineer of M5Stack
        tech@m5stack.com
        M5Stack documentation URL
        https://docs.m5stack.com
        • KabronK
          Kabron
          I also have a question. I got M5Fire in M5Bala set.
          Half of USB-C does not work, i.e.: in one position PC does discover device, while in 180 degrees opposite - does not.
          Is it a kind of warranty case?
          I wrote to official M5Store seller on aliexpress, but got no answer.
            ajb2k3 @Kabron
            @kabron get a new lead, I get this with an expensive leads.
            • KabronK
              Kabron @ajb2k3
              @ajb2k3 在 Warranty question M5stack is dead 中说:
              You mean to try another cable? I tried all I have.
                ajb2k3 @Kabron
                @kabron I brought 4 different ones before I found one that works in any direction.
                I ended up paying £20 for a lead and that only works if the usb C connector is in a certain rotation.
                Yes I brought 4 leads spending over £30 just on leads!
                • m5-docsM
                  m5-docs @Kabron
                  Hi, kabron @kabron Does your Type-C cables work now?
                  • KabronK
                    Kabron @m5-docs
                    @watson 在 Warranty question M5stack is dead 中说:
                    It works in only one direction(position).
                    • m5-docsM
                      m5-docs @Kabron
                      @kabron
                      Hi
                      You means that only one direction(positive) which USB-C cables inserted to PC, and PC will discover usable Serial Port.
                      If you turn USB-C cable around 180 degrees, the serial port will disappear.
                      Do I descripte your phenomenon correctly?
                      • KabronK
                        Kabron @m5-docs
                        Absolutelly correct.
                        I have to mark socket sides of all my cables
