    Can microSD card be accessed in UIFlow or with MicroPython?
    Micropython
    12
    35.3k
    • lukasmaximusL
      Not possible in uiflow yet. Micropython is easy
      import os
      os.mountsd()
      os.listdir('/sd')
      etc...
      Z 1 Reply Last reply Reply Quote 0
      • Z
        zhufu86 @lukasmaximus
        @lukasmaximus
        thank you for your reply.
        But when I tried to exec os.mountsd I got an error as below.
        os.mountsd()
        W (20141) sdspi_host: spi bus changed (1 -> 2)
        E (20141) sdspi_host: spi bus 2 not available
        E (20141) vfs_native: Failed to initialize SDcard (258).
        OSError: [Errno 5] EIO
          ajb2k3 @zhufu86
          @zhufu86 said in Can TF card be accessed in UIFlow or with MicroPython?:
          @lukasmaximus
          os.mountsd()
          Can you post all you code please
          • Z
            zhufu86 @ajb2k3
            I just exec in REPL.
            import os
            os.mountsd()
            nothing else....
            I also tried os.SDMODE_4LINE, os.SDMODE_1LINE and os.SDMODE_SPI with os.sdconfig(...) before mountsd(), but none of them worked.
            Forgot to say, I'm using M5Stack Fire.
              ajb2k3 @zhufu86
              import os
              os.mountsd()
              nothing else....
              You also need the machine, sdcard and dpi library imported. That’s why I recommend that you visit MicroPython.org
              • Z
                zhufu86 @ajb2k3
                thank you.
                I went to MicroPython.org but found nothing helpful.
                Finally, I erased the firmware and burned the M5S with the UIFlow-v1.3.1-Beta firmware.
                It worked, with the code below.
                >>> import uos
                >>> uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs=4)
                I (53596) gpio: GPIO[23]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                I (53596) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                I (53604) gpio: GPIO[18]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull             down: 0| Intr:0
                >>> uos.mountsd()
                W (65959) sdspi_host: spi bus changed (1 -> 2)
                I (65959) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulld             own: 0| Intr:0
                 Mode: SPI
                     Type: SDHC/SDXC
                    Speed: default speed (25 MHz)
                SPI speed: 40 MHz
                      CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9
                      SCR: sd_spec=2, bus_width=5
                • Z
                  zhufu86
                  Funny...
                  I re-burned back to UIFlow-v1.2.3, and it also worked.
                  >>> import uos
                  >>> uos.mountsd()
                  W (104277) sdspi_host: spi bus changed (1 -> 2)
                   Mode: SPI
                       Type: SDHC/SDXC
                  SPI speed: 20 MHz
                  • Z
                    zhufu86
                    Here I attach the webpages which helps me mostly.
                    Hope it can help other people.
                    https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/filesystems
                    https://forum.micropython.org/viewtopic.php?t=4551
                    https://loboris.eu/forum/showthread.php?tid=85
                    Z 1 Reply Last reply Reply Quote 1
                    • Z
                      zhufu86 @zhufu86
                      ok......
                      now even one simple uos.mountsd() also works...
                      good...
                      >>> import uos
                      >>> uos.mountsd()
                      W (497494) sdspi_host: spi bus changed (1 -> 2)
                       Mode: SPI
                           Type: SDHC/SDXC
                      SPI speed: 20 MHz
                      • H
                        hema41
                        Yes, microSD cards can be accessed in UIFlow or with MicroPython. They allow you to read and write data from/to the microSD card, enabling storage and retrieval of information on compatible devices.
