    UiFlow 2.0
    77
    191
    499.5k
    • C
      ciconde
      Slider unit missing
      • J
        jazztunes
        Perhaps previously reported, but I don't see the "red port" rotary encoder unit (U135) in UIFLOW2. Any ideas?
        Alpha-24
        V2.0.0
        F 1 Reply Last reply Reply Quote 2
        • F
          flex @jazztunes
          @IAMLIUB0
          do developers of UIFlow are reading M5Stack Community Forum, to take into account the bugs we can encounter, or is there any special bug report to do somewhere else?
          I notified few months ago and also recently, that UIFlow 2.0 doesn't work with Apple IOS, while UIFlow 1.12 works correctly, in term of creating designing UI items...
          Thank you for your feedback
          Pascal
          • E
            erich
            Hi there,
            Sorry I just need a confirmation: Alpha-26: Is it right built-in Infrared is not (yet, hopefully) supported on the M5StickC PLUS? I cannot find IR in the integrated hardware menu.
            Also, I have noticed support for M5StickC Plus 2 , is it an upgraded M5StickC Plus not out yet? I am very interested ;)
            Thanks for your answers!
            G B 2 Replies Last reply Reply Quote 0
            • G
              gavin67890 @erich
              Hi @erich,
              There's a snippet here about StickPlus2
              https://twitter.com/M5Stack/status/1682320261708926977
              Also interested, but it seems a limited spec change to overcome obsolescence. If there is work being done on the IR code blocks, it would be a nice feature to get full NEC IR code support.
              • E
                erich @gavin67890
                @gavin67890 thanks a lot for the link!
                I agree it does not look much different from the current stickcplus. Also I see it was supposed to be launched end of July… let’s wait and see
                • K
                  kotobuki
                  • J
                    jonbloom
                    Just picked up some M5 Dials, they're great. Could we possible get BLE GATT support in UIFlow 2? The UART blocks are great, but allowing services/characteristics/notifications with BLE would open up for interacting with various BLE based IoT devices easily.
                    • B
                      bazman @erich
                      @erich
                      Here's the FCC submission for M5StickC Plus 2 include internal and external photos:
                      https://apps.fcc.gov/eas/GetApplicationAttachment.html?id=6654502
                      Apparent differences to M5StickC Plus 1.1:
                      • AXP192 is removed as it is end-of-line
                      • Magnet is now one small disc instead of two small bars
                      • battery lead is socketed
                      • now one board instead of two
                      • IC is ESP32-PICO-V3-02 instead of ESP32-PICO-D4 (now doesn't support external PSRAM, not relevant though). PICO-V3 has extra pin 20 for internal use.
                      • 200mAh battery instead of 120mAh
                      • Not clear where the buzzer is or whether there is no buzzer - not on the inside back as per M5 Stick C Plus.
                      • The rear sticker shows a few differences in internal GPIO pin allocations.
                      The twitter post @gavin67890 linked to says its been delayed due to some further changes though.
                      • E
                        erich
                        @bazman thanks!
                        • K
                          korffr
                          Hi Everyone,
                          I am using an M5Stack CoreS3 and UIFlow2 Alpha-27.
                          I am new to ESP32 and M5Stack, so not sure if this is a bug in UIFlow2, MicroPython, or it is expected behavior and my understanding of the way it should work is incorrect... :-)
                          I am trying to update labels with values on a regular basis, the label is in front of a rectangle and the background of the label is the same color as the foreground of the rectangle.
                          However, it seems that when I update the label text, and the length of the text is smaller than the previous length, it leaves an empty space at the back of the label with the background color. I.e., it does not re-render the 'missing part' of the rectangle.
                          I could redraw the rectangle after the update, but then the rectangle will overwrite the text.
                          I could redraw the rectangle and then rewrite the text, but if the value has not changed, it will not write it on the screen and it remains hidden.
                          The only way to do it is to make the label text empty, draw the rectangle, and then fill the label text with the new value.
                          That seems like a lot of work just to update a single text label, it also sometimes introduces a flicker (I have quite a number of labels to update)
                          Is this a bug ? And is there any way around this (without having to clear and redraw all the screen elements one-by-one)?
                          Here is a minimum program to show the issue:
                          And the output:
                          Richard
                            mumin50 @IAMLIUBO
                            @iamliubo m5dial is not fully suported missing NFC ... Also i have nice IR python script for raw codes (without decoding) is there a option to make a module from it...
                            I spend some time reading comments above... and started to think i made mistake trying to use m5stack devices ...
                              Hello guys
                              Hardware: M5AtomS3 core, PaHUB unit and EXTIO2 unit (connected to channel 5 of the PaHUB).
                              Firmware: UIFlow 2.0.0 Alpha-28
                              The UIFlow block Init extio2_0 generates the following Micropython code:
                              extio2_0 = EXTIO2Unit(PAHUB(i2c=i2c0, channel=5))
                              which results in a runtime error: NameError: name 'PAHUB' isn't defined.
                              The correct (for me working) code is:
                              extio2_0 = EXTIO2Unit(PAHUBUnit(i2c=i2c0, channel=5))
                              e.g. instead of PAHUB it shoud be PAHUBUnit.
                              • J
                                j_doe
                                Hi.
                                As @felmue mentioned in the previous post uiflow is generating wrong code for the pahub. When can we expect this to be corrected? I guess uiflow has the problem?
                                Best Regards
                                JOn Magnus Dullerud
                                  sgu
                                  The M5Stack Core S3 is now released for 6 Months and still the uiflow 2.0 is in beta phase and supports 2 Mopdules only.
                                  I'm asking me for what the Core S3 can be used ?.
                                  In the M5 Burner, there is no UI Flow 1.x for the Core S3!
                                  So at the moment the Core S3 has only limited functionality with the UI Flowe in alpha version.
                                  Is this the quality of M5 Stack ?
                                  • A
                                    applebearsnowman
                                    hardware: core 2 for aws
                                    When I choose run once my .py file in APP.LIST(or APP.RUN). It always said some modules not define.
                                    Choose Run always would work though.
                                    I think is some problems about import module
                                    because I tried "M5.Widgets.fillScreen(0x222222)" instead " Widgets.fillScreen(0x222222)", and it works.
                                    My imports have two of these:
                                    import M5
                                    from M5 import *
                                    • J
                                      jdbaluch @sgu
                                      @sgu I too have been worried about this, as I jumped in feet-first to m5stack and figured the lastest and greatest devices would also have the best support. Its silly that something as trivial as displaying the current battery level requires code execution blocks. I had to order an older device just so I can test out some of the modules and sensor units I purchased. Think I'm just gonna give up on UIFLow and invest my time in Arduino IDE.
                                      • D
                                        dsrc12 @j_doe
                                        @j_doe I need help with this one. Cannot get any UART program to work on CoreS3 with UIFlow2. I am using CoreS3 as a co-processor to a Raspberry Pi using serial coms but my initial unit testing is being done on a Windows PC working with Putty. Here is the program:
                                        What I want is an equivalent program to this which uses an original Core computer. It is based on UIFlow 1 (V12.1.9)
                                        I am using the latest firmware & on-line UIFlow IDEs (Alpha-28)
                                        On the Core program I had to decode before I could access text from the UART - might need a similar solution for UIFlow2?
                                        On the UIFlow1 program I accessed the Core UART using pins TX:1 & RX:3. I am guessing that the equivalent pins for CoreS3 are TX:43 & RX:44?
                                          Meldrak
                                          What is the status of adding features to UIFlow2? I recently bought the core, core2, and core3, as well as the M5Paper. I am having a blast with blockly for the core, but most of the blockly code is missing in UIFlow2. For example, getting the current battery status is missing. There isn't an option for power in hardware, like there is in UIFlow. I also would like to request you do not change the GPIO again. For me half of the draw to the M5stack devices is that the modules and sensors work out of the box. Having modules that no longer work with the core3 due to a different GPIO pinout sucks. Keep up the good work and please take these as suggestions and not complaints. I love your product, I just want more software support in the form of UIFlow2. Thanks!
                                          • lbuqueL
                                            lbuque @dsrc12
                                            @dsrc12 RX: G18/TX: G17
