    Arduino code for PaHuB2 + any I2C sensor
    5 Posts 3 Posters 4.7k Views 1 Watching
    • E Offline
      EKTan
      Dear all,
      I looking for the sample code reading the values from the I2C module (like ENV III) that is connected to the PaHUB2 socket 0 (PaHUB2 has I2C address 0x71).
      Thank you.
      • E Offline
        EKTan
        Dear all,
        I'm looking for the sample Arduino code to read the ENV III module that is connected to the PaHUB2 socket 0 (PaHUB2 has an I2C address 0x71).
        Thank you.
        • teastainT Offline
          teastain @EKTan
          @ektan Sorry, this took me all day to write and de-bug.
          It is an ENVIII on position 0 and ENVII on position 1, as that is what I have!
          #include <M5Stack.h>  //use any controller by substituting the library
          #include "M5_ENV.h"
          SHT3X sht30;  // creates ONE instance!!!
          float tmp1 = 12.3;
          float hum1 = 0.0;
          float tmp2 = 12.3;
          float hum2 = 0.0;
            M5.Power.begin();
            delay(100);
            Wire.begin();
            sht30.init();
            Wire.beginTransmission(0x70);  //(the PaHub)
            Wire.write(0x00);              //turns off all ports
            Wire.endTransmission();        // as it says!
            M5.Lcd.setTextSize(3);         //or lower for StickC
            M5.Lcd.setTextColor(RED);
            M5.Lcd.print("Setup  ");
            delay(1000);
            Wire.write(0x01);              //turns on port 0, ENV1
            if (sht30.get() == 0) {   // Obtain the data of shT30.
              tmp1 = sht30.cTemp;     // Store the temperature obtained from shT30.
              hum1 = sht30.humidity;  // Store the humidity obtained from the SHT30.
                       } else {
              tmp1 = 0, hum1 = 0;
            delay(100);
            Wire.write(0x02);              //reads the ENV at port 1
              tmp2 = sht30.cTemp;     // Store the temperature obtained from shT30.
              hum2 = sht30.humidity;  // Store the humidity obtained from the SHT30.
              } else {
              tmp2 = 0, hum2 = 0;
            delay(100);
            M5.Lcd.fillRect(0, 0, 320, 80, BLACK);
            M5.Lcd.setCursor(5, 5);
            M5.Lcd.print("Temp1=  ");
            M5.Lcd.setCursor(130, 5);
            M5.Lcd.print(tmp1, 1);  //one decimal place
            M5.Lcd.setCursor(5, 50);
            M5.Lcd.print("Temp2=  ");
            M5.Lcd.setCursor(130, 50);
            M5.Lcd.print(tmp2, 1);  //one decimal place
            delay(1000);
          There is no PaHub library because the Wire C-code is in-line with the Arduino code.
          This is actually easier to understand and illustrates how the PaHub works.
          -Terry
          E C 2 Replies Last reply Reply Quote 0
          • E Offline
            EKTan @teastain
            @teastain
            Thank you so much for the help.
            It works perfectly...
              crami25 @teastain
              @teastain In Arduino you can uise the PCA9548 library .
              Example : https://randomnerdtutorials.com/tca9548a-i2c-multiplexer-esp32-esp8266-arduino/
