m5stack cardputer doesn't turn on.
Hello @ajb2k3
using M5Burner I've downloaded the below firmware to my M5Cardputer. Then measured G0, G1, G2 and G46 while the firmware was running.
NEMO for | Marauder for | Cardputer | Volos Cardputer Cardputer | Cardputer | User Demo | TV Remote v2.4.1 | v0.13.6 | v0.9.1 | v1.0 G0 3.3 V | 3.3 V | 3.3 V | 3.3 V G1 3.3 V | 3.3 V | 3.3 V | 3.3 V G2 3.3 V | 3.3 V | 3.3 V | 3.3 V G46 3.3 V | 0 V | 0 V | 3.3 V
Note: Downloading firmware from M5Burner always put the M5StampS3 into download mode automatically - at no point did I have to manually set it to download mode using G0 button.
Note: I am on Ubuntu 20.04
@teastain I thought you was Volos for a while
@felmue Thanks, It looks like that Serial/JTAG is the default mode unless USB OTG is set.
Thats what I though, Nemo and Marauda are pulling G0 high
@felmue You are thorough.
@felmue said in m5stack cardputer doesn't turn on.:
Hello @ajb2k3
FelixIs there any way I can reset it so it turns back on?
@sl4sh00 Yes.
What app did you try to install?
That could be the root of the problem.
The BootLoader firmware is unbreakable, so there is no real problem.
@Sl4sh00 can you try this...press and hold boot button (on side of cardputer or top of stamp) while holding connect usb then let button go, then try to load fresh firmware in M5Burner.
@teastain marauder
@robski I tried holding down the reset button but nothing happened, is there any other way to install the firmware?
@sl4sh00 To put it into 'download' mode you can do as @robski suggested or:
Press and hold the G0 Boot button...while holding it in, press and release the reset button, THEN release the G0 Boot.
While doing this you can check the connection status in whatever burner app you are using.
Please tell us if you can see the connection status AT ALL, this would be helpful in solving your problem.
@teastain Thank you my brother, it works just like you said. Now it works again.
@sl4sh00 Thank you for getting back to us!
@teastain bro thank u so mutch i tried it the whole day but nothing helped thank u so mutch , God bless you
@teastain i tried the same for my cardputer but no luck
@sl4sh00 said in m5stack cardputer doesn't turn on.:
m5stack cardputer doesn't turn on, after I connected it to the computer and tried to put an app on the M5Burner and it didn't turn on anymore and when I plug it into the computer it keeps connecting and
Comprei um cardputer para mim, quero saber como faço para instalar as aplicações do git hub, e só baixar e passar para o cartão sd .
@gera5034 baixa o M5Burner no site da M5. nele vc põe a opção do cardputer e aparece os apps q funcionam nele.
