M5Stick's OLED screen with UI.Flow
Can I use M5Stick's OLED screen with UI.Flow?
@tomorrow56
Not sure if the function has been enabled yet.
I know that the M5 has grown so much that there is a code back log.
Thanks... I will try to use OLED by Arduino IDE.
Hi, Happy New Year!
Recently, uiflow has supported m5stick. And you can use m5stick's OLED screen with uiflow.
Here's the documentation and example code for stick:https://docs.m5stack.com/#/zh_CN/core/m5stick
https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Core/M5Stick/UIFlow
Thanks for your support!
Maybe, Graphic Block and Emoji Block are not working now...
