    M5Dial RFID not working in UIFlow 2.0
    Bug Report
    2.0k
    • L
      LittleBit670
      I was making a simple program that should be able to pair to an NFC/RFID card using its UID and then be able to compare the saved UID against another scanned card's UID.
      This is the Python code output from UIFlow:
      import os, sys, io
      import M5
      from M5 import *
      from hardware import *
      import time
      mode = None
      status = None
      rfid = None
      savedcard = None
      # Describe this function...
      def pair():
        global savedcard, mode, status, rfid
        Speaker.tone(3500, 50)
        Widgets.fillScreen(0xff6600)
        mode.setText(str('Setup Mode'))
        status.setText(str('Scan tag to pair'))
        while not (rfid.is_new_card_present()):
          continue
        savedcard = rfid.read_card_uid()
        status.setText(str(str((rfid.read_card_uid()))))
        time.sleep(1)
        reset()
      def active():
        Widgets.fillScreen(0x666666)
        if savedcard == None:
          mode.setText(str('Active Mode'))
          status.setText(str('No tag paired'))
          time.sleep(1)
          pair()
        else:
          status.setText(str('Waiting for tag'))
            pass
          if (rfid.read_card_uid()) == savedcard:
            Widgets.fillScreen(0x33cc00)
            status.setText(str('Access granted'))
            time.sleep(1)
          else:
            Widgets.fillScreen(0xcc0000)
            status.setText(str('Access denied'))
            for count in range(3):
              time.sleep_ms(60)
            time.sleep(1)
        reset()
      def reset():
        Widgets.fillScreen(0x000000)
        mode.setText(str('Idle'))
        status.setText(str('Click to wake'))
      def btnA_wasClicked_event(state):
        global mode, status, rfid, savedcard
        active()
      def btnA_wasHold_event(state):
        pair()
      def setup():
        rfid = RFID()
        M5.begin()
        mode = Widgets.Label("[mode]", 36, 87, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
        status = Widgets.Label("[status]", 35, 122, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
        BtnA.setCallback(type=BtnA.CB_TYPE.WAS_HOLD, cb=btnA_wasHold_event)
        reset()
        Speaker.setVolumePercentage(1)
      def loop():
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
      When I hold the button to enter Setup Mode and scan a tag, the output of the UID read always comes out as "None" meaning nothing's there. I don't know why this is happening, so this is why I'm sending this as a bug report.
        Hello @LittleBit670
        I think reading the UUID twice in a short time could be the issue. Try changing below line:
        #  status.setText(str(str((rfid.read_card_uid()))))
          status.setText(str(savedcard))
