    AtomDTU NB-IoT
    32 Posts 2 Posters 34.1k Views
    • felmueF Online
      Hello @Felix22
      it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
      See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
      The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
        Felix22
        Result:
        b'\r\nOK\r\n'
        b'\r\nOK\r\n'
        b'\r\nOK\r\n'
        b'\r\nOK\r\n'
        b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
        b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
        b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
        Im a big step wider... now, i have become my ip address... :-)
        Now i think... MQTT, next step.
          Felix22
          Juhuuuu !!
          It works !
          More Information and the solution will follow...
          @felmue : many thanks
          • felmueF Online
            Hello @Felix22
            I am happy to hear you got it working.
              Felix22
              now, i have a new problem.
              The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
              I see no difference...
              The orange part is working and the tree other is not working
              • Domainname
              • IP-Address
              • Dyndns
                not working...
                test.mosquitto.org is working fine.
              • felmueF Online
                Hello @Felix22
                hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                  Felix22
                  you mean the blocks at "Fortgeschritten" / MQTT ?
                  over there it connects over Wlan/Wifi...
                  Is there a MQTT-Block how i can say the RX and TX pin ?
                  • felmueF Online
                    Hello @Felix22
                    no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                      Felix22
                      this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                      But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                      Do you also use the Atom DTU NB-IoT ?
                      • felmueF Online
                        Hello @Felix22
                        not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                        And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                        • felmueF Online
                          Hello @Felix22
                          I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                            Felix22
                            Do you have a list with the Status Codes ?
                            Signal Qualität: 16
                            MQTT-Connection: 0
                            Network-Registration: 7
                            GPRS network registration
                            • felmueF Online
                              Hello @Felix22
                              sure, here you are:
                              • Signal Quality: 17
                              • MQTT-Connection: 0
                              • Network Registration: 7
                              • GPRS Network Registration: 5
                              and when connected to MQTT broker
                              • MQTT-Connection: 1
                                Felix22
                                Hello Felix
                                By the error code I meant what the individual numbers mean.
                                Each code 0 to x
                                Do you have a code list ?
                                Greeting
                                • felmueF Online
                                  Hello @Felix22
                                  no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
