    ADD display block not working on M5Stamp S3
    UiFlow 2.0
    3.5k
      I cant get an SV7789 SPI display working using the following code in UIFLow2
        Hello @ajb2k3
        check out my example M5StampS3_LCD_ST7789V2_UIFlow2.0.2 in the Play Zone. It looks like the backlight PWM part is not working properly, e.g. the display stays dark. I fixed that by setting the backlight GPIO to HIGH manually.
          Nope, just cant get it to work, I get the backlight lit up but nothing else
            Hello @ajb2k3
            for me the display only works when selecting SPI host ID SPI3.
            BTW: I just figured out that PWM actually works, but the default brightness (127) is too low to see. Using st7789.setBrightness(255) sets a visible brightness.
              I just can't get the ST7789 working on a StampS3 using the Unified driver.
              I'm trying to use this display
              https://www.amazon.co.uk/gp/product/B07ZP4QK3S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
              And the stamp1.27 through the mate adapter.
                Hello @ajb2k3
                did you verify this ST7789 works at all? Maybe it is broken?
                I found this tutorial and it looks like this ST7789 display should work without backlight wire connected.
                BTW: I run my test with an ST7789 display taken from an M5StickCPlus.
                  It was a brand new display out of the bag. There is a chance I may have killed it wiring +&- back to front but the backlight still works
