    193 Posts 78 Posters 538.1k Views 13 Watching
    • B Offline
      BritOnTour @dissy
      @dissy said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
      @britontour You may wish to completely start over with the pairing process.
      1. Put your device in programming mode and use m5burner to do an 'erase'
      2. In uiflow2, click the button to select a device to connect to, and hover the mouse over your device icon. In the top right of that icon (when hovered over) should be a square you can click to edit the device info. In there should be an 'unregister device' button to fully delete it.
      3. Back in m5burner, reflash uiflow2 to the device and configure for your wifi.
      I'm stuck at step 3. I connect to the device in WebBurner (you say m5Burner, but that doesn't support S3), then click on "Configure" and enter the wifi credentials. When I click Confirm, I get an error message:
      Error
      Request failed. Check the network and try again!
      Looking in the developer tab of Chrome, there is a 404 error attempting to download from https://uiflow2.m5stack.com/m5stack/api/v2/device/downloadBin
      Is this a server issue, or a problem with my connection?
      • B Offline
        BritOnTour @BritOnTour
        @britontour I found the m5burner that supports S3. I had an older version for my original Core, and didn't realize there was a new version.
        It took a couple of tries, but I managed to bind and reflash the S3. I confirmed that the PUBLIC switch was active before flashing. Once complete, my screen still shows is at a PRIVATE device, and uiflow2 still shows a red dot next to it in the public list. The device info also shows it as PUBLIC. uiflow2 will not connect to it.
        dissyD 1 Reply Last reply Reply Quote 0
        • dissyD Offline
          dissy @BritOnTour
          @britontour If m5burner registered the device into uiflow, and it shows having a MAC and Token value (partially masked out), then it should be re-paired properly.
          I'm unsure why your device can not connect to the server to report itself online.
          I've just verified the process still works (I don't have a core s3 but used a cardputer which is stamp s3 based)
          I did just discover a bug in the 2.0.2 "develop" screen. It may be cardputer specific, but it incorrectly displays "private" in both modes. It's just a display bug though, it isn't effecting my connection
          • B Offline
            BritOnTour @dissy
            @dissy I see "PRIVATE" on the Develop screen of the S3, even though I configured it as Public. This is what I see in uiflow2 GUI when I click on the device button.
            What server connection does it need? I may need to get IP or ports whitelisted at my office.
            • B Offline
              BritOnTour
              My only way to connect to my S3 is USB cable. I click on the run button, and a web terminal window appears. I select the COM port and press connect. Press the play button at the top and I see my python code downloading. at the end , I get an error message (see below). If the line number is referring to my python code, I don't see what the problem is.
              Line 68: rectOrigin = None
              Line 102: if lengthTargetCycles >= 3:
              Line 103: txtTargetCycles3.setText(str(listTargetCycles[2]))
              File "<stdin>", line 68
              SyntaxError: invalid syntax
              Occasionally, the line number changes.
              File "<stdin>", line 102
              • dissyD Offline
                dissy @BritOnTour
                @britontour said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                Before it connects it will read "private" in yellow, and show "user account" as "none"
                After it successfully connects this will change and should show "public" in green and your email address in "user account"
                https (port 443) to host uiflow2.m5stack.com
                • B Offline
                  BritOnTour
                  My IT guy helped me work out the issue with the connection to the server. Access to ntp.aliyun.com was blocked. I changed it to our local gateway ntp server and I can connect to the S3 successfully over wifi!! Onto the next bug!!
                  • B Offline
                    BritOnTour
                    A new Bug!
                    What does this mean? It doesn't change from 0%
                    • B Offline
                      BritOnTour
                      My issue with Sync is also fixed. It was another issue with aliyun.com access restriction by my company's IT dept
                      • B Offline
                        BritOnTour
                        OK, so I am finally making progress with my design, and I see so many features missing that really should be available for a modern development environment. There is no option for design reuse, code sharing, custom functions, etc. If I want to use some example code, I have to recreate each step in my project.
                        Moving from uiflow1 to uiflow2, I had to rebuild every block of my design. If I find something useful in an example project, I can't just copy/paste from one window to the other, again, I have to manually rebuild what I want in my project.
                        Is there a roadmap for planned features to be added to uiflow2?
                        • teastainT Offline
                          teastain @BritOnTour
                          @britontour Maybe it is time for you to expand into Arduino IDE where all your complaints are answered.
                          -Cheers
                            Kris @IAMLIUBO
                            @iamliubo Why only DAC hat is available with m5staick? No more hats?
                            ajb2k3A 1 Reply Last reply Reply Quote -1
                              ajb2k3 @Kris
                              @kris said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                              Because it take time to write and develop the code so that it doesn’t cause breakers in other code
                              • Z Offline
                                zendes
                                Hi. I'm missing the 4-Relay Unit in the list of possible devices. Can you please add that back, as it exists in uiflow 1?
                                  Hello @zendes
                                  maybe my example (PlayZone: M5Dial_4RelayUnit_UIFlow2.0.1) can help out until the native 4-relay unit gets added in UIFlow2.
                                  Note: you might need to modify the I2C pins for SCL and SCK dependent on the core you are using.
                                    sorphin
                                    1_1712280273337_Screen Shot 2024-04-04 at 6.22.56 PM.png 0_1712280273336_Screen Shot 2024-04-04 at 6.24.02 PM.png
                                    • W Offline
                                      wmatkins
                                      @dlhawley
                                      These are current products for sale in the M5 store. Wasn't the NCIR-2 introduced over two years ago? I think there would have been ample time to integrate them into the latest UIFlow.
                                        Hello @wmatkins
                                        re: NCIR hat : I think it should work by adding the NCIR unit but with a custom I2C setting, e.g. SCL=26 and SDA=0.
                                        Note: I do not have the NCIR hat or unit so I cannot test this myself.
                                          Hello @sorphin
                                          I can confirm that in M5Dial UIFlow2.0.3 firmware the blocks for the built-in RFID reader are not working and throw an error. However, as a workaround, I used the blocks of a virtual RFID unit (and modified I2C SCL and SDA pins) to successfully read RFID cards with the internal RFID reader. See PlayZone M5Dial_RFID_UIFlow2.0.3 example.
                                            sorphin @felmue
                                            @felmue Thanks for confirming as well Felix. I did find that I could make it work in a round about way as well (using rfid.RFID (no parenthesis)).. but one shouldn't have to do that :/
