M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0
I'm using M5Burner on MacOS. After I burned UIFlow2.0 to my Cardputer, I can't burn any other .bin files.
Now, I can only access the develop button on my Cardputer. How can I reset it back to the original shipping firmware? Any help would be greatly appreciated. Thank you!
@lamfan You need to put the cardputer into "Bootloader" mode to burn firmware.
@ajb2k3 said in M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0:
Thanks @ajb2k, I can burn the firmware now. Can you tell me where I can get the shipping firmware?
I love to use the keyboard and radio app. Thank you!
@lamfan it is there in M5Burner already (or was last time I checked
@ajb2k3 found it, thank you!
hi guys!! I have worst error for my cardputer , now says:
Erase Flash
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 17, in <module>
import esptool
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/init.py", line 816
raise FatalError(f"Unable to verify flash chip connection ({e}).")^
SyntaxError: invalid syntax
Captura de pantalla 2024-05-06 a las 01.24.26
help please
That means that it didn't detect the controller. are you sure you have the correct USB data cable connecting the controller to the host computer and have installed the drivers along with ESP-IDF?
@ajb2k3 hi mate, not sure how that can be checked but as soon I plug the cardputer the system do.
how can I confirm if my mac have the right drivers needed?
thanks in advance....
Captura de pantalla 2024-05-06 a las 12.07.47
@rolf_steiner said in M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0:
my last update is this status now.....
after all my intents to fix this situation, now trying to "burn" appears this:
Captura de pantalla 2024-05-06 a las 13.57.27
sad thing, this frustrates a lot.
in other hand, i can't format any Micro SD if I put one in the cardputer....
good morning mate!
thanks for all you support!!If I follows the youtube link, step by step, after the actions required at the second 44, this appears in my screen:
Captura de pantalla 2024-05-07 a las 11.31.05I´m lost..... I cant understand why doesnt recognize the cardputer....
Try a different USB cable
Results after changing USB cable:
Captura de pantalla 2024-05-07 a las 17.52.46looks like the device are connected in a right manner, but half second later appears the "Get mac failed" in red rectangle.
Weird thing is the message inside the "Burn UIFIow2" area, in every "cancel, erase, start" button the loading circle keeps moving eternally.....
