@kris said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
@iamliubo Why only DAC hat is available with m5staick? No more hats?
Because it take time to write and develop the code so that it doesn’t cause breakers in other code
Hi. I'm missing the 4-Relay Unit in the list of possible devices. Can you please add that back, as it exists in uiflow 1?
Hello @zendes
maybe my example (PlayZone: M5Dial_4RelayUnit_UIFlow2.0.1) can help out until the native 4-relay unit gets added in UIFlow2.
Note: you might need to modify the I2C pins for SCL and SCK dependent on the core you are using.
Felix -
These are current products for sale in the M5 store. Wasn't the NCIR-2 introduced over two years ago? I think there would have been ample time to integrate them into the latest UIFlow. -
Hello @wmatkins
re: NCIR hat : I think it should work by adding the NCIR unit but with a custom I2C setting, e.g. SCL=26 and SDA=0.
Note: I do not have the NCIR hat or unit so I cannot test this myself.
Felix -
Hello @sorphin
I can confirm that in M5Dial UIFlow2.0.3 firmware the blocks for the built-in RFID reader are not working and throw an error. However, as a workaround, I used the blocks of a virtual RFID unit (and modified I2C SCL and SDA pins) to successfully read RFID cards with the internal RFID reader. See PlayZone M5Dial_RFID_UIFlow2.0.3 example.
Felix -
@felmue Thanks for confirming as well Felix. I did find that I could make it work in a round about way as well (using rfid.RFID (no parenthesis)).. but one shouldn't have to do that :/
I have 3 issues currently:
This is very fast (less than a minute).When I use UiFlow 2.0's web interface to upload my program (~20KB) via USB in the web terminal, however, It is very very slow (~2-3 minutes).
The issue also happens when I upload a file from the web terminal.
When I upload a file or program, it results in an empty (0 Bytes) file! (most of the time), I burned the old Alpha-29 version of UIFlow 2 on my device using M5Burner, and this problem is fixed -
Half of the time, when I run the program, the colors are inverted (instead of RGB, it's BGR, literally)
I would like to use the touchscreen on the M5Dial. But the block M5.Touch.getCount() does not work in a while loop! It only works in the main loop. So the touchscreen is hardly usable in Micropython. I have not been able to realize the waiting for a touch.
Hello @Peter
the trick is to add an
M5.update()
statement (using anExecute mpy Code
block) inside the while loop.
See UIFlow2 Project Zone example: M5Dial_Touch_Get_Count_In_While_Loop_UIFlow2.0.4Thanks
Felix -
@felmue Thanks Felix, it works:)
I didn't look to the Project Zone. I'll do it now. -
Hi...
How to add custom block (m5b) to UiFlow2.0??? -
Is there any way to port projects from UiFlow 1 to UiFlow 2 (.m5f to .m5f2)?
I've been searching in the forum but didn't find any message about it.
I've to start all my development from zero or there is any way to port projects from one system to the another?
I've several developments for M5StickC.
If it is possible, I think it must be put more visible how to do it. If it's not possible, it must be warning in some place to be visible too.
Thanks.
