    193 Posts 78 Posters 539.4k Views 13 Watching
      Hello @wmatkins
      re: NCIR hat : I think it should work by adding the NCIR unit but with a custom I2C setting, e.g. SCL=26 and SDA=0.
      Note: I do not have the NCIR hat or unit so I cannot test this myself.
        Hello @sorphin
        I can confirm that in M5Dial UIFlow2.0.3 firmware the blocks for the built-in RFID reader are not working and throw an error. However, as a workaround, I used the blocks of a virtual RFID unit (and modified I2C SCL and SDA pins) to successfully read RFID cards with the internal RFID reader. See PlayZone M5Dial_RFID_UIFlow2.0.3 example.
          sorphin @felmue
          @felmue Thanks for confirming as well Felix. I did find that I could make it work in a round about way as well (using rfid.RFID (no parenthesis)).. but one shouldn't have to do that :/
          • CAT the TechC Offline
            CAT the Tech
            I have 3 issues currently:
            • 1
              This is very fast (less than a minute).
              When I use UiFlow 2.0's web interface to upload my program (~20KB) via USB in the web terminal, however, It is very very slow (~2-3 minutes).
              The issue also happens when I upload a file from the web terminal.
            • 2
              When I upload a file or program, it results in an empty (0 Bytes) file! (most of the time), I burned the old Alpha-29 version of UIFlow 2 on my device using M5Burner, and this problem is fixed
            • 3
              Half of the time, when I run the program, the colors are inverted (instead of RGB, it's BGR, literally)
              Peter
              I would like to use the touchscreen on the M5Dial. But the block M5.Touch.getCount() does not work in a while loop! It only works in the main loop. So the touchscreen is hardly usable in Micropython. I have not been able to realize the waiting for a touch.
                Hello @Peter
                the trick is to add an M5.update() statement (using an Execute mpy Code block) inside the while loop.
                See UIFlow2 Project Zone example: M5Dial_Touch_Get_Count_In_While_Loop_UIFlow2.0.4
                  Peter @felmue
                  @felmue Thanks Felix, it works:)
                  I didn't look to the Project Zone. I'll do it now.
                    Raed.Alnuaimi
                    Hi...
                    How to add custom block (m5b) to UiFlow2.0???
                      HéctorD
                      Is there any way to port projects from UiFlow 1 to UiFlow 2 (.m5f to .m5f2)?
                      I've been searching in the forum but didn't find any message about it.
                      I've to start all my development from zero or there is any way to port projects from one system to the another?
                      I've several developments for M5StickC.
                      If it is possible, I think it must be put more visible how to do it. If it's not possible, it must be warning in some place to be visible too.
                      Thanks.
                        CAT the Tech
                        Since update 2.0.9, the buttons on my M5Stack Stick C Plus 2 have been tangled and unusable
                        The button A and power button (aka button C) are now unresponsive. Their respective callbacks do not get triggered at all.
                        The button B will trigger the callback for button A!
                        Here is my test program:
                        import os, sys, io
                        import M5
                        from M5 import *
                        from hardware import *
                        import time
                        def btnA_wasPressed_event(state):
                          print('Pressed A')
                        def btnA_wasReleased_event(state):
                          print('Released A')
                        def btnB_wasPressed_event(state):
                          print('Pressed B')
                        def btnB_wasReleased_event(state):
                          print('Released B')
                        def btnPWR_wasPressed_event(state):
                          print('Pressed PWR')
                        def btnPWR_wasReleased_event(state):
                          print('Released PWR')
                        def setup():
                          print('hello M5')
                          M5.begin()
                          BtnA.setCallback(type=BtnA.CB_TYPE.WAS_PRESSED, cb=btnA_wasPressed_event)
                          BtnA.setCallback(type=BtnA.CB_TYPE.WAS_RELEASED, cb=btnA_wasReleased_event)
                          BtnB.setCallback(type=BtnB.CB_TYPE.WAS_PRESSED, cb=btnB_wasPressed_event)
                          BtnB.setCallback(type=BtnB.CB_TYPE.WAS_RELEASED, cb=btnB_wasReleased_event)
                          BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_PRESSED, cb=btnPWR_wasPressed_event)
                          BtnPWR.setCallback(type=BtnPWR.CB_TYPE.WAS_RELEASED, cb=btnPWR_wasReleased_event)
                        def loop():
                          M5.update()
                          time.sleep_ms(50)
                        if __name__ == '__main__':
                          try:
                            setup()
                            while True:
                              loop()
                            try:
                              print_error_msg(e)
                            except ImportError:
                        All was working well in UiFlow 2.0.8 yesterday, please fix this so I can continue to use it.
                          CAT the Tech
                          I also tried some other methods since, none of them had the desired effect:
                          Method 2 - Pin buttons
                          • This method works only with mode High (pull_low=False), with or without pull
                          • It is incredibly slow to respond (about 1 second)
                          import os, sys, io
                          import M5
                          from M5 import *
                          import time
                          Btn37 = None
                          Btn39 = None
                          Btn35 = None
                          def btn37_wasPressed_event(state):
                            global Btn37, Btn39, Btn35
                            print('Pressed A')
                          def btn39_wasPressed_event(state):
                            print('Pressed B')
                          def btn35_wasPressed_event(state):
                          def btn35_wasReleased_event(state):
                          def btn39_wasReleased_event(state):
                            print('Released B')
                          def btn37_wasReleased_event(state):
                            print('Released A')
                          def setup():
                            print('hello M5')
                            M5.begin()
                            # Pin 37 == button A
                            # Pin 39 == button B
                            Btn37.setCallback(type=Btn37.CB_TYPE.WAS_PRESSED, cb=btn37_wasPressed_event)
                            Btn37.setCallback(type=Btn37.CB_TYPE.WAS_RELEASED, cb=btn37_wasReleased_event)
                            Btn39.setCallback(type=Btn39.CB_TYPE.WAS_PRESSED, cb=btn39_wasPressed_event)
                            Btn39.setCallback(type=Btn39.CB_TYPE.WAS_RELEASED, cb=btn39_wasReleased_event)
                            Btn35.setCallback(type=Btn35.CB_TYPE.WAS_PRESSED, cb=btn35_wasPressed_event)
                            Btn35.setCallback(type=Btn35.CB_TYPE.WAS_RELEASED, cb=btn35_wasReleased_event)
                          def loop():
                            M5.update()
                            Btn37.tick(None)
                            Btn39.tick(None)
                            Btn35.tick(None)
                            time.sleep_ms(50)
                            try:
                              setup()
                              while True:
                                loop()
                              try:
                                print_error_msg(e)
                              except ImportError:
                          Method 3 - machine.Pin (IRQ)
                          • It is fast, responsive
                          • It cannot report accurately if the button was pressed or released if multiple events are queued one after the other
                          import os, sys, io
                          import M5
                          from M5 import *
                          import time
                          from machine import Pin
                          pin37 = None
                          pin39 = None
                          pin35 = None
                          p = None
                          # Describe this function...
                          def button_callback(p):
                            global pin37, pin39, pin35
                            i = int(str(p)[4:-1])
                            print(f"Button id: {i}, value: {p.value()}")
                          def setup():
                            print('hello M5')
                            M5.begin()
                            pin37 = Pin(37, mode=Pin.IN)
                            pin39 = Pin(39, mode=Pin.IN)
                            pin35 = Pin(35, mode=Pin.IN)
                            pin37.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                            pin39.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                            pin35.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=button_callback)
                          def loop():
                            M5.update()
                            time.sleep_ms(50)
                            try:
                              setup()
                              while True:
                                loop()
                              try:
                                print_error_msg(e)
                              except ImportError:
                          Edit:
                          Oh, right, I almost forgot.
                          There is no such thing as the following in the machine.Pin method:
                          p.irq().flags()
                          I don't know if it is because of the micropython port you guys use or if it is the esp32-pico-v3-02's fault, but I think there is something missing there...
                          • lbuqueL Offline
                            lbuque @CAT the Tech
                            @CAT-the-Tech I tried running your code and found that it works well.
                            CAT the TechC 1 Reply Last reply Reply Quote 0
                              CAT the Tech @lbuque
                              @lbuque Really?
                              Which method did you use? (1, 2, or 3)
                              What device are you using?
                                CAT the Tech
                                Since version 2.1.0, The Pin Buttons method (method 2) does not work AT ALL anymore
                                • lbuqueL Offline
                                  @CAT-the-Tech stickc_plus2
                                  • lbuqueL Offline
                                    cores3 works fine
                                      @lbuque Weird...
                                      Can you show me the StickC Plus 2's code you used?
                                      Are you sure your core3 AND StickC Plus 2 are at the latest version? (2.1.0 as of yesterday) (You can see this when it boots, in the terminal)
                                        digiponta
                                        I need it supports M5Stack DIN base with M5 stack/S3.
                                        • lbuqueL Offline
                                          lbuque @digiponta
                                          @digiponta said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                          DIN base does not require software support, it can be used directly.
                                            CAT the Tech @CAT the Tech
                                            @lbuque I tried some more ideas to make the buttons work again:
                                            M5 buttons - manual loop
                                            • Same results as the original M5 buttons method (button A and PWR (C) won't work no matter what, and button B thinks it is button A)
                                            import os, sys, io
                                            import M5
                                            from M5 import *
                                            import time
                                            def button_check():
                                              if BtnA.wasPressed():
                                                print('Pressed A')
                                              if BtnA.wasReleased():
                                                print('Released A')
                                              if BtnB.wasPressed():
                                                print('Pressed B')
                                              if BtnB.wasReleased():
                                                print('Released B')
                                              if BtnPWR.wasPressed():
                                              if BtnPWR.wasReleased():
                                            def setup():
                                              print('hello M5')
                                              M5.begin()
                                            def loop():
                                              M5.update()
                                              button_check()
                                              time.sleep_ms(50)
                                              try:
                                                setup()
                                                while True:
                                                  loop()
                                                try:
                                                  print_error_msg(e)
                                                except ImportError:
                                            Pin buttons - manual loop
                                            Okay, so this one is an absolute monster via blockly (visual editor)
                                            • Same results as the original Pin buttons method (it takes some time for the buttons to register the actions and the press/release is inverted))
                                            import os, sys, io
                                            import M5
                                            from M5 import *
                                            import time
                                            Btn37 = None
                                            Btn39 = None
                                            Btn35 = None
                                            code_str = None
                                            Btn37_last_state = None
                                            Btn39_last_state = None
                                            Btn35_last_state = None
                                            def button_check():
                                              global code_str, Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                                              if execute_mpy_code('Btn37.wasPressed()') and not Btn37_last_state:
                                                print('Pressed A')
                                                Btn37_last_state = True
                                              elif execute_mpy_code('Btn37.wasReleased()') and Btn37_last_state:
                                                print('Released A')
                                                Btn37_last_state = False
                                              if execute_mpy_code('Btn39.wasPressed()') and not Btn39_last_state:
                                                print('Pressed B')
                                                Btn39_last_state = True
                                              elif execute_mpy_code('Btn39.wasReleased()') and Btn39_last_state:
                                                print('Released B')
                                                Btn39_last_state = False
                                              if execute_mpy_code('Btn35.wasPressed()') and not Btn35_last_state:
                                                Btn35_last_state = True
                                              elif execute_mpy_code('Btn35.wasReleased()') and Btn35_last_state:
                                                Btn35_last_state = False
                                            def execute_mpy_code(code_str):
                                              global Btn37_last_state, Btn39_last_state, Btn35_last_state, Btn37, Btn39, Btn35
                                              return eval(code_str)
                                            def setup():
                                              global Btn37, Btn39, Btn35, Btn37_last_state, Btn39_last_state, Btn35_last_state
                                              print('hello M5')
                                              M5.begin()
                                            def loop():
                                              M5.update()
                                              Btn37.tick(None)
                                              Btn39.tick(None)
                                              Btn35.tick(None)
                                              button_check()
                                              time.sleep_ms(50)
                                              try:
                                                setup()
                                                while True:
                                                  loop()
                                                try:
                                                  print_error_msg(e)
                                                except ImportError:
                                            I believe my unit is not the issue, because the machine.Pin method worked as expected (except that I cannot get the state of the button the moment the callback was called)
                                            What are the next steps / things to try?
