    Re-Burn original firmware on M5Paper
    SOFTWARE
    973
      MMorin
      Greetings to all. A question from an enthusiastic newcomer: how do I reinstall the original (factory) firmware on my M5Paper? Thanks in advance! (I'm also very happy working with the CompuCard!)
      All the best,
      Michel Morin
      Montreal
        ajb2k3 @MMorin
        @mmorin you use M5Burner and the factory firmware should be in there
        • T
          turgu @ajb2k3
          @ajb2k3 I'm on Linux using the M5Burner, can't see the original factory firmware. Here are the entries: UIFlow2, UIFlow, FactoryTest, Calculator, WeatherStation, ToDo, OnlineImage.
            ajb2k3 @turgu
            @turgu Factory test or the UIFlows is the original firmware.
            • T
              turgu @ajb2k3
              @ajb2k3 Thanks for the information. I was able to install it with the M5Burner, but can't get it to start. Tried to remove the usb cable, reseted the device with the back pin and turned it on with the push button on the side, nothing happened.
                ajb2k3 @turgu
                @turgu did you erase the old firmware off the M5Paper before burning the new firmware?
                • T
                  turgu @ajb2k3
                  @ajb2k3 Thanks for your reply. Yes I did erased the flash. Any other ideas??
