    i2c driver install error
    UiFlow 2.0
    9
    15
    13.5k
    • L
      LucidXVR
      dda9c819-581d-4f1a-92f9-8db984efbf9d-image.png i dont know how to fix it, ive tried two versions of uiflow and theres nothing on youtube or google or any stuff like that. any help?
      • kurikoK
        kuriko @LucidXVR
        @LucidXVR
        known issue, seems doesn't affect anything, will fix it soon
        K H 2 Replies Last reply Reply Quote 0
        • felmueF felmue referenced this topic on
        • K
          kmk68 @kuriko
          @kuriko Yes, it affects. The program does not start on my M5 Core after this message....
          • kurikoK
            kuriko @kmk68
            @kmk68
            Are you able to show your code?
            K 1 Reply Last reply Reply Quote 1
            • K
              kmk68 @kuriko
              @kuriko it's created by block editing...
              import os, sys, io
              import M5
              from M5 import *
              from label_plus import LabelPlus
              from hardware import *
              import time
              from unit import EncoderUnit
              label0 = None
              label1 = None
              label2 = None
              label3 = None
              BtnA = None
              BtnB = None
              BtnC = None
              rect0 = None
              rect1 = None
              rect2 = None
              rect3 = None
              rect4 = None
              rect5 = None
              rect6 = None
              rect7 = None
              rect8 = None
              rect9 = None
              rect10 = None
              rect11 = None
              rect12 = None
              rect13 = None
              rect14 = None
              rect15 = None
              rect16 = None
              rect17 = None
              rect18 = None
              rect19 = None
              label7 = None
              label8 = None
              label9 = None
              label10 = None
              label11 = None
              label12 = None
              label13 = None
              LA_4 = None
              LA_3 = None
              LA_2 = None
              LA_1 = None
              LB_4 = None
              LB_3 = None
              LB_2 = None
              LB_1 = None
              LC_4 = None
              LC_3 = None
              LC_2 = None
              LC_1 = None
              pin3 = None
              pin1 = None
              pin2 = None
              pin5 = None
              i2c1 = None
              pin25 = None
              pin26 = None
              pin35 = None
              pin36 = None
              encoder_0 = None
              l_enc_inc = None
              INT_clock = None
              t_values = None
              enc_mode = None
              curr_value = None
              loc_value = None
              Describe this function...
              def init_all_out_pins_as_():
              global l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value, label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0
              pin3 = Pin(3, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin1 = Pin(1, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin2 = Pin(2, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin5 = Pin(5, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin25 = Pin(25, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin26 = Pin(26, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin35 = Pin(35, mode=Pin.OUT, pull=Pin.PULL_UP)
              pin36 = Pin(36, mode=Pin.OUT, pull=Pin.PULL_UP)
              def relay_outs_pin_set():
              if t_values[-1] == INT_clock:
              pin3.value(1)
              if t_values[0] == INT_clock:
              pin1.value(1)
              if t_values[1] == INT_clock:
              pin2.value(1)
              if t_values[2] == INT_clock:
              pin5.value(1)
              if t_values[3] == INT_clock:
              pin25.value(1)
              if t_values[4] == INT_clock:
              pin26.value(1)
              if t_values[5] == INT_clock:
              pin35.value(1)
              if t_values[6] == INT_clock:
              pin36.value(1)
              if t_values[7] == INT_clock:
              pin25.value(0)
              if t_values[8] == INT_clock:
              pin26.value(0)
              if t_values[9] == INT_clock:
              pin35.value(0)
              if t_values[10] == INT_clock:
              pin36.value(0)
              if t_values[7] + 25 == INT_clock:
              pin3.value(0)
              if t_values[8] + 25 == INT_clock:
              pin1.value(0)
              if t_values[9] + 25 == INT_clock:
              pin2.value(0)
              if t_values[10] + 25 == INT_clock:
              pin5.value(0)
              def all_out_pins_to_zero():
              pin3.value(0)
              pin1.value(0)
              pin2.value(0)
              pin5.value(0)
              pin25.value(0)
              pin26.value(0)
              pin35.value(0)
              pin36.value(0)
              def setup():
              global label0, label1, label2, label3, BtnA, BtnB, BtnC, rect0, rect1, rect2, rect3, rect4, rect5, rect6, rect7, rect8, rect9, rect10, rect11, rect12, rect13, rect14, rect15, rect16, rect17, rect18, rect19, label7, label8, label9, label10, label11, label12, label13, LA_4, LA_3, LA_2, LA_1, LB_4, LB_3, LB_2, LB_1, LC_4, LC_3, LC_2, LC_1, pin3, pin1, pin2, pin5, i2c1, pin25, pin26, pin35, pin36, encoder_0, l_enc_inc, INT_clock, t_values, enc_mode, curr_value, loc_value
              M5.begin()
              Widgets.fillScreen(0x222222)
              label0 = Widgets.Label("Key 1", 4, 185, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label1 = Widgets.Label("Key 1", 4, 135, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label2 = Widgets.Label("Key 2", 5, 85, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label3 = Widgets.Label("Key 4", 5, 35, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              BtnA = Widgets.Label("A", 60, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
              BtnB = Widgets.Label("B", 150, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
              BtnC = Widgets.Label("C", 240, 222, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
              rect0 = Widgets.Rectangle(100, 40, 40, 25, 0xffffff, 0x0f0957)
              rect1 = Widgets.Rectangle(143, 40, 40, 25, 0xffffff, 0x0f0957)
              rect2 = Widgets.Rectangle(186, 40, 40, 25, 0xffffff, 0x0f0957)
              rect3 = Widgets.Rectangle(229, 40, 40, 25, 0xffffff, 0x0f0957)
              rect4 = Widgets.Rectangle(100, 68, 40, 25, 0xffffff, 0x0f0957)
              rect5 = Widgets.Rectangle(143, 68, 40, 25, 0xffffff, 0x0f0957)
              rect6 = Widgets.Rectangle(186, 68, 40, 25, 0xffffff, 0x0f0957)
              rect7 = Widgets.Rectangle(229, 68, 40, 25, 0xffffff, 0x0f0957)
              rect8 = Widgets.Rectangle(100, 96, 40, 25, 0xffffff, 0x0f0957)
              rect9 = Widgets.Rectangle(100, 124, 40, 25, 0xffffff, 0x0f0957)
              rect10 = Widgets.Rectangle(100, 152, 40, 25, 0xffffff, 0x0f0957)
              rect11 = Widgets.Rectangle(143, 96, 40, 25, 0xffffff, 0x0f0957)
              rect12 = Widgets.Rectangle(186, 96, 40, 25, 0xffffff, 0x0f0957)
              rect13 = Widgets.Rectangle(229, 96, 40, 25, 0xffffff, 0x0f0957)
              rect14 = Widgets.Rectangle(143, 124, 40, 25, 0xffffff, 0x0f0957)
              rect15 = Widgets.Rectangle(186, 124, 40, 25, 0xffffff, 0x0f0957)
              rect16 = Widgets.Rectangle(229, 124, 40, 25, 0xffffff, 0x0f0957)
              rect17 = Widgets.Rectangle(143, 152, 40, 25, 0xffffff, 0x0f0957)
              rect18 = Widgets.Rectangle(186, 152, 40, 25, 0xffffff, 0x0f0957)
              rect19 = Widgets.Rectangle(229, 152, 40, 25, 0xffffff, 0x0f0957)
              label7 = Widgets.Label("A", 159, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label8 = Widgets.Label("B", 202, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label9 = Widgets.Label("C", 243, 46, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label10 = Widgets.Label("K4", 112, 74, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label11 = Widgets.Label("K3", 113, 102, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label12 = Widgets.Label("K2", 113, 129, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              label13 = Widgets.Label("K1", 113, 157, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)
              LA_4 = LabelPlus("0,0", 153, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LA_3 = LabelPlus("0,0", 153, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LA_2 = LabelPlus("0,0", 153, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LA_1 = LabelPlus("0,0", 153, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LB_4 = LabelPlus("0,0", 195, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LB_3 = LabelPlus("0,0", 195, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LB_2 = LabelPlus("0,0", 195, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LB_1 = LabelPlus("0,0", 195, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LC_4 = LabelPlus("0,0", 239, 74, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LC_3 = LabelPlus("0,0", 239, 102, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LC_2 = LabelPlus("0,0", 239, 129, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              LC_1 = LabelPlus("0,0", 239, 157, 1.0, 0x9aff00, 0x000000, Widgets.FONTS.DejaVu12, "http://", 3000, False, None, "error", 0xFF0000)
              i2c1 = I2C(1, scl=Pin(22), sda=Pin(21), freq=100000)
              t_values = bytearray(12)
              enc_mode = 0
              curr_value = 0
              INT_clock = 0
              encoder_0 = EncoderUnit(i2c1, 0x40)
              def loop():
              M5.update()
              time.sleep_us(20)
              if INT_clock == 0:
              time.sleep_ms(99)
              INT_clock = INT_clock + 1
              l_enc_inc = encoder_0.get_rotary_increments()
              if encoder_0.get_button_status():
              encoder_0.fill_color(0x990000)
              enc_mode = 1
              if l_enc_inc != 0:
              curr_value = curr_value + l_enc_inc
              while curr_value < 0:
              curr_value = curr_value + 12
              while curr_value > 11:
              curr_value = curr_value - 12
              else:
              encoder_0.fill_color(0x000066)
              enc_mode = 0
              if l_enc_inc != 0:
              loc_value = t_values[int(curr_value - 1)] + l_enc_inc
              if loc_value < 0:
              loc_value = 0
              if loc_value > 99:
              loc_value = 99
              t_values[int(curr_value - 1)] = loc_value
              if curr_value==0:
              LA_4.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==1:
              LA_3.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==2:
              LA_2.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==3:
              LA_1.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==4:
              LB_4.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==5:
              LB_3.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==6:
              LB_2.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==7:
              LB_1.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==8:
              LC_4.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==9:
              LC_3.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==10:
              LC_2.setText(str(((str((loc_value / 10))).strip())))
              elif curr_value==11:
              LC_1.setText(str(((str((loc_value / 10))).strip())))
              else:
              pass
              if name == 'main':
              try:
              setup()
              while True:
              loop()
              try:
              print_error_msg(e)
              except ImportError:
              • kurikoK
                kuriko @kmk68
                @kmk68
                Can you export .m5f2 file on UiFlow2?
                • C
                  Calvorotas
                  I have problems with UiFlow 2.2.0.
                  I could use BLE with UiFlow 2.1.8, but the same program doesn't run in 2.2.0.
                  The progam can't start. The device return at Uiflow main menu.
                  I have update UiFlow in the devices (Core M5stack and StickC, but I have the same problem.
                  Thanks.
                  C kurikoK 2 Replies Last reply Reply Quote 0
                  • C
                    Calvorotas @Calvorotas
                    @Calvorotas
                    Another program without BLE.
                    I am not using MQTT in this program.
                    Thanks.
                    • kurikoK
                      kuriko @Calvorotas
                      @Calvorotas
                      can you provide the .m5f2 file? imma do a test to check out if it's a firmware problem
                      nmstackN C 2 Replies Last reply Reply Quote 0
                      • _
                        _e3e6
                        Same issue here with Atom Echo and the Web UIFlow 2.0
                        https://gist.github.com/e3e6/f8558f8487dad2fe8909c8dc17b80888
                        • nmstackN
                          nmstack @kuriko
                          @kuriko
                          There is a few days ago, I wrote a similar trouble. My message was…
                          I didn't think that I could feel so interested about this system! Sorry for my questions about, because I'm very unexpert.
                          I'm math teacher in secondary in Spain, and I want to prepare a trigonometric practice very simple.
                          I've used a potenciometer (angle unit), PaHUB, PbHUB, 8servos unit, and two servos: one 360º limited, and another one, 360º unlimited. Until this moment, all was right. But, I've done some little changes, I wasn't conscient that, when I erased the PaHUB unit, and I added another one, some address changed. I reviewed all the program, and I think that it should run. But, I don't know why now, when my program is running, at the end of compilation, it appears this message "E (112496) i2c: i2c driver install error".
                          Thank you for your attention
                          Please, does someone aid me?
                          Thank you for my poor English. Best regards!
                          Neus
                          Neus Morlà
                          • C
                            Calvorotas @kuriko
                            @kuriko
                            This is the file.
                            1 Reply Last reply Reply Quote 4
                            • H
                              Hulkco @kuriko
                              @kuriko Several months have passed since this post, but the error persists. Do you really plan to fix it?!
                              M 1 Reply Last reply Reply Quote 2
                                mearsuit @Hulkco
                                yep...Same problem, i cant upload any python code without getting this error. Its a shame because its a really neat dev board and i really wish the people at m5stack would fix this problem. They would begin to see more projects being posted on the m5burner and it would only help their sales. Screenshot_2025-09-25_18-21-33.png
                                robskiR 1 Reply Last reply Reply Quote 1
                                • robskiR
                                  robski @mearsuit
                                  @mearsuit i see this error from some time but projects are working ok
