    PPS 13.2 Arduino Can not compile the example Sketch
    Modules
    arduino pps compile
    1.8k
    • P
      plackettsj1
      *******Hi,
      I am new to the forum and have just purchased a PP2 13.2. There is an Arduino library that I wish to use for automation . I can not compile the example Sketch for any board . So please could you tell me which chipset this example is designed to work with and then I can work out what to try and fix -
      As a newbie - I would also be grateful if you can tell me if the PPS 13.2 will work standalone with the arduino or whether or not I need to get something else?
      Simon
        felmue @plackettsj1
        Hello @plackettsj1
        the PPS 13.2 module is meant to be used with an ESP32/ESP32S3 based M5Core like M5Stack, M5Core2 or M5CoreS3 - see PPS documentation here.
        • P
          plackettsj1 @felmue
          @felmue Thank-you - I had completely misunderstood :-)
          Simon
