    Burning micropython firmware without specifying wifi details
    UiFlow 2.0
    • H
      hmwavem
      I'm trying to play around with the dial, however I'm running into a bit of an issue-- when burning the firmware, you're required to give wifi details. I'm content to use it over usb for now, so I just gave dummy information however I want to try to set up the dial as an access point. I'm just getting an 'invalid wifi mode' error when i try to run it however, and I'm wondering if having the init try to set up a connection like that is interfering. Does the dial actually support running it as an AP, or is the existence of it in uiflow 2.0 an error? How can I get it to work?
        felmue @hmwavem
        Hello @hmwavem
        works for me. See example in UIFlow2 Project Zone: M5Dial_WiFi_AP_UIFlow2.2.1
