    m5dial: wifi not work when rfid is enabled
    6 Posts 4 Posters 3.9k Views
      studiosacchetti
      even a simple code like this can raise my problem
      //connect to WiFi
      Serial.printf("Connecting to %s ", ssid);
      WiFi.begin(ssid, password);
      delay(500); Serial.print(".");
      Serial.println(" CONNECTED");
      with this config setting everything is ok
      M5Dial.begin(cfg, false, false);
      but if i enable rfid
      M5Dial.begin(cfg, false, true);
      m5dial can connect only once to my wifi network, i have a fritzbox router
      any idea?
      • G Offline
        gadgetguy @studiosacchetti
        @studiosacchetti Did you ever solve this issue? I am now having exactly the same issue.
          Slarck
          The RFID module might be interfering with the WiFi signal. Try using a different power source or check if the RFID is drawing too much current and test with a different router or 2.4GHz channel.
          • G Offline
            gadgetguy @Slarck
            @Slarck Thanks will look into those. I don't need them simultaneously, I tried turning the RFID on/off, but once I turn it on (after doing a server packet test), even if I turned it off Wifi still doesn't work.
            • G Offline
              gadgetguy @gadgetguy
              @Slarck So I have hooked up a 12V power supply to the power connector (2pin green). It doesn't help, I can't connect to the Wifi when the RFID is enabled.
              Any ideas? I tried turning the RFID off when I connect to the wifi
              M5Dial.begin(cfg, true, false); // enable encoder, disenable RFID
              but once I turn on the RFID, it doesn't seem that turning it off enables the Wifi.
              If I never enable the RFID, then I can connect to the Router, so I don't think my router or channel is an issue.
              Any other ideas welcome.
                felmue @gadgetguy
                Hello @gadgetguy
                I can confirm that enabling RFID prevents M5Dial from connecting to WiFi.
                After enabling RFID in M5Dial.begin(cfg, true, true), try M5Dial.Rfid.PCD_AntennaOff() to temporarily disable RFID while using WiFi, then after disconnecting from WiFi enable RFID again with M5Dial.Rfid.PCD_AntennaOn().
