    Certificate based MQTT (AWS IoT) trouble with changed umqtt
    Micropython
      sistar_hh
      unfortunately the micropython certificate handling for MQTT has been changed last year. good description
      Here is the new way to do it:
       # Create an SSL context
          context = ssl.SSLContext(ssl.PROTOCOL_TLS_CLIENT)
          context.verify_mode = ssl.CERT_REQUIRED
          # Load certificates
          context.load_verify_locations(cafile='/flash/certificate/ca.der')
          context.load_cert_chain('/flash/certificate/cert.der', '/flash/certificate/key.der')
          mqtt = MQTTClient(client_id=client, server=endpoint, port=8883, keepalive=1200, ssl=context)
          print("Connecting to AWS IoT...")
          mqtt.connect()
          print("Done")
      While the code and certificates work fine on ESP32-S3 Micropython they result in the following error on uiflow2
        File "<stdin>", line 74, in <module>
        File "<stdin>", line 52, in mqtt_connect
        File "/flash/libs/umqttn/simple.py", line 69, in connect
        File "ssl.py", line 1, in wrap_socket
      ValueError:
      The certificate validity has expired
      I triple checked the certificate validity..
      Next suspect would be an incorrect system time. Therfore I set the time as follows before attempting to initialize a mqtt connection:
      sta_if = network.WLAN(network.STA_IF)
      sta_if.active(True)
      if sta_if.isconnected():
          sta_if.disconnect()
      sta_if.connect(wifi_ssid, wifi_password)
      while not sta_if.isconnected():
          utime.sleep(1)
          print("Connecting...")
      print("Connected:", sta_if.ifconfig())
      print(f"time before NTP settime {time.localtime()}")
      ntptime.settime()
      print(f"time after NTP settime {time.localtime()}")
      import machine
      rtc = machine.RTC()
      # Set manually to a known correct UTC date/time: (year, month, day, weekday, hour, minute, second, microsecond)
      rtc.datetime((2025, 3, 14, 1, 14, 0, 0, 0))
      print("Manually set time:", machine.RTC().datetime())
      Still I get the same error:
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connected: ('192.168.5.0', '255.255.252.0', '192.168.4.1', '192.168.4.1')
      time before NTP settime (2025, 3, 14, 12, 8, 44, 5, 72)
      time after NTP settime (2025, 3, 14, 12, 8, 45, 5, 72)
      Manually set time: (2025, 3, 14, 5, 14, 0, 0, 67)
      MQTT Connection failed:
        File "<stdin>", line 79, in <module>
        File "<stdin>", line 57, in mqtt_connect
      ValueError:
      I used the micropython/umqtt.simple/umqtt/simple.py implementation installed as module umqttn in the /flash/libs folder. It differs from the m5stack implementation (which is currently broken for certificate based MQTT due to the described changes in Micropython).
      At this point I wonder why the same code (umqtt.simple, demo-code, exactly the same certificate files) work on an UMFeatherS2 MicroPython v1.24.1 but fail on MicroPython v1.24.0-dirty on 2025-03-06; M5STACK CoreS3 with ESP32S3.
      I would happy for any hint on how to solve this.
        sistar_hh
        @sistar_hh said in Certificate based MQTT (AWS IoT) trouble with changed umqtt:
        # Load certificates
        mqtt.connect()
        print("Done")
        ValueError:
        sta_if.active(True)
        sta_if.disconnect()
        utime.sleep(1)
        ntptime.settime()
        import machine
        rtc = machine.RTC()
        Connecting...
        Connecting...
        Connecting...
        Connecting...
        ValueError:
        Aha! When trying the following change:
        context.verify_mode = ssl.CERT_OPTIONAL # Instead of CERT_REQUIRED
        I successfully connected!
