    AIN4-20ma Raspberry Pi Detection
    Units
    16
    5.2k
    • A
      andrew.winton @robski
      I was hoping there wasn't something unique about the I2C on these, so I'm glad you confirmed that, however it's still confusing why I can't even detect it. Here it is with the stack module hooked up https://docs.m5stack.com/en/module/AIN4-20mA%20Module%2013.2. When I have SDA and SCL disconnected, an i2cdetect immediately returns no results. When I hook them up, i2cdetect crawls through each address until they time out. I've double checked the pinouts, and made sure I'm supplying 12v (also tried 24v) to the 9-24V high voltage plug, and that it's getting 5v from the Pi.
      Yellow - 5v
      Brown - Ground
      Orange - SDA
      Red - SCL
      • robskiR
        robski
        so you have M5base here not sure about that as there is M-bus in it.
        But you also mentioned single channel unit was behiving same right?
        • A
          @robski Yes, the single channel unit was behaving the exact same way.
          • robskiR
            robski @andrew.winton
            @andrew-winton do you have any other M5Stack unit on i2c to be checked possibly, not AIN unit I mean.
            • A
              @robski I do not. I was considering getting a core and base to make sure it worked with those first to rule out the device.
                felmue @andrew.winton
                Hello @andrew-winton
                I don't have a RP4 nor do I have the AIN4-20mA module so my tests might be irrelevant for your setup.
                Using an RP3 and about every M5Stack I2C unit I have (RFID, Relay4, PaHub, PbHub, EXTIO, etc.), all of them get detected just fine using i2cdetect -y 1.
                That said:
                • have you verified that there are proper pull-up resistors on SCL and SDA? (RP should have them by default.)
                • have you tried with different wires?
                • have you tried w/o supplying 12 v? I think it's redundant looking at the schematic. (External 12 V power also produces BUS_5V which might clash with the 5 V from RP.)
                • have you tried to reduce the I2C speed? (default seems to be 100k)
                robskiR A 2 Replies Last reply Reply Quote 0
                • robskiR
                  robski @felmue
                  I'm bk home tday for weekend and I have AIN single chnl unit so I'll try to check it out.
                  • A
                    andrew.winton @felmue
                    @felmue RP has the pull-ups by default. Although these are brand new wires, I've tried different ones. I've also tried it with and without the power to the stack. I've also tried speeds of 50k, 100k, and 400k, which have all worked for other i2c devices on the Pi.
                    • robskiR
                      @andrew-winton I've checked my AIN module with RPi4 and i can confirm that it is not detecting it, plugged in ENV module, ACCEL module, ultrasound module and i2c scan detects it straight in, when AIN is plugged in scan goes fast to place where it should be detected ( 0x55 i think) and then without its ID detection scan continues but slowly like 1s for every next ID field till the scan end
                      • robskiR
                        robski @robski
                        @andrew-winton tday I had a chance to test AIN with raspberry pico 2 W and it is detetcting ok
                        RaspberryPico2W with AIN
                        • A
                          @robski Yeah I had seen that behavior with it jumping to the right address and then crawling after not finding it.
