Wifi Invalid Mode
Hi All,
I have an issue where, if I create this as main.py, I will get an error when I try to start my M5 paper. The error is Wifi Invalid Mode.
My script is below. I have the same configuration in M5 burner and it seems to correctly trying to start main.py as I get the error straight away. If I chose to show the menu at start up then I can see the M5 paper in UIFlow 2 and I can see the device has connected to my account. Any ideas? It's a bit of a pain having choose the app from the applist on the devices screen, but I can run it like that. My app is a bit more complicated than this but this script does the same thing:
import os, sys, io
import M5
from M5 import *
import networklabel0 = None
wlan = Nonedef setup():
global label0, wlanwlan = network.WLAN(network.STA_IF)
M5.begin()
Widgets.fillScreen(0xeeeeee)
label0 = Widgets.Label("label0", 124, 542, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)wlan.connect('network', 'testtesttest')
label0.setFont(Widgets.FONTS.DejaVu24)
label0.setText(str(wlan.ifconfig()[0]))def loop():
global label0, wlan
M5.update()if name == 'main':
try:
setup()
while True:
loop()
try:
print_error_msg(e)
except ImportError:
print("please update to latest firmware")Thanks,
Hello @JensH
please check my example in UIFlow2 Project Zone: M5Paper_WLAN_Test_UIFlow2.2.5
Felix -
Thanks Felix. I've added the same delay as in your code and that has fixed my issue. I still have an error in the terminal if I have it connected to my PC but at least the app is functioning now and I can restart my M5 Paper straight into the app.
Thanks very much for your help.
J
