M5Stack - Simple Applications Menu + some APPs
New version:
Added:
APP - GY-512 (MPU6050) - gyro/accelerometer
APP - variable speed Serial PASS-THRU USB<->UART2
SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
Serial Commands - WiFiScan, I2CScan
@TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
I get errors on all
[code]
#pragma mark
[/code]Will comment out and try again
@kryten Please specify the error. Arduino version. Take PrintScreen.
Do you have installed M5.libraries ? ESP32 libraries ?
@tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
APP - GY-512
very nice system!
APP - GY-512 works also with built-in MPU9250 :)Can You modify TIM MEASUREMENT APP?
S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
@reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
@jimit Hi, good work. But I did not find the code on your git ...
@tomsuch
Oops... sorry bout that. Have added them now....
@jimit OK, I'm going to check it out ..
@jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
@tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
@jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
@tomsuch
Awesome... all wifi scanner functions working perfectly - thou i couldn't test the page function due to lack of networks... excellent work Tom !! Thanks for making it happen.
@jimit No problem Jim. Regards....
Would be awesome to have a generic menu system so you could focus only on core development.
I have tried to use yours for my app but had no time to fully understand it.
Could you write a little doc explaining how can we use it in our apps?
@tomsuch Hi Tom, I have change the code of my Branch and like to pull it back to yours. But you have advanced your Code quick and my branch is now behind yours. So I would like to ask you to look over my code and if you like what you see, then I want to integrate it into your master.
The next step is, I have tried Push Button based WPS, first with a LOLIN32 and now with the M5Stack and I like to add this to your SAM in the new way I added the the appBME280.
@sunwukong Hi, Thank you for the subject. I will look at it.
For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
http://forum.m5stack.com/topic/85/m5stacksam-application-menu-library
@kaotiklabs Hi, Thank you for the subject. I will look at it.
@m5stack For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.
