    timescamps of the photos taken by V-training
    M5Stick V
    • N
      naofuruta
      When I take photos with V-traning, all the timestamps on the photos are set to 2075. How can I fix this?
      • Y
        yuyun2000 @naofuruta
        @naofuruta The issue with the timestamp being set to 2075 on photos taken with V-Training is likely due to a firmware or configuration problem. Here’s how you can fix it:
        Steps to Resolve:
        Update Firmware:
        Ensure your M5StickV or the device running V-Training has the latest firmware installed. Outdated firmware can cause incorrect timestamps.
        Download the latest firmware from the M5Stack official website.
        Check RTC (Real-Time Clock):
        The device’s RTC might not be properly set. Use the following steps to sync the time:
        Connect the device to Wi-Fi (if supported) to sync the time automatically.
        Manually set the RTC using the device’s configuration menu or via a script.
        Reconfigure V-Training:
        Reset the V-Training application settings to default and reconfigure it.
        Ensure the timestamp settings in the app are correctly configured.
        Verify SD Card:
        A corrupted or improperly formatted SD card can cause timestamp issues. Format the SD card to FAT32 and try again.
        Factory Reset:
        If the issue persists, perform a factory reset on the device and reinstall the firmware and V-Training application.
        Additional Notes:
        If the problem continues, contact support@m5stack.com for further assistance.
        Provide details such as the device model, firmware version, and steps you’ve already tried.
        https://chat.m5stack.com/
