    Program upload error stickC plus2
    M5 Stick/StickC
      marcj091
      Firstly, my apologies, although willing to learn I am completely ignorant of the complexities involved to something that I thought would be easy to use without needing any intermediate understanding of programming.
      And so with my Luddism exposed I now ask for someone to pity me and help resolve my problem, please.
      I bought a stickC Plus2 and the soil moisture with pump unit.
      I followed the instructions and also built the watering program as on the demonstration video at the bottom of the units webpage
      In UIflow2 and saved it to the cloud.
      After downloading and installing the software for the m5 burner and specified driver, I found that it will not work on my mac. I have no hub to connect through either so I can not try that option.
      So I used my father’s windows laptop, completed the same procedure and successfully burned the UIflow2 software to the stickC plus2.
      I get a nice warm feeling when I do something that I deem as clever and outside of my wheelhouse… yay me!
      Now my problem seems to arrive when I attempt to send the watering program made on blockly, to the stick.
      I get the following message on the terminal popup and also on the stick2.
      I have googled sections of the script but it returns nothing that I recognise, or make any sense of.
      Could someone possibly help me?
      TIA
      Web Terminal •
      Row
      24
      Col
      94
      apped Pa Serial Rors!
      (510560) i2c: i2c driver install error
      E
      E
      (510602) transport_base: tep_read error, errno-Software caused connection abort
      (510602) ngtt_client: esp_mgtt_handle_transport_read_error: transport_read() error: errno=11
      E
      (510607) M5Things: Last error captured as transport's socket errno: 0x71
      E (510613) mgtt client: mqtt process_receive: mqtt message_receive () returned -2
      [INFO] Syncing resources...
      [INFO] WiFi connected!
      E (512835) i2c: i2c driver install error
      Traceback (most recent call last) :
      File "main-PY", line 32, in ‹module>
      File "main-PY", line 16, in setup File "label plus-Py", line 33, in init ValueError: invalid Timer number
      MicroPython v1.25.0-dirty on 2025-06-27; MSSTACK StickC PLUS2 with ESP32 (SPIRAM)
      • kurikoK
        kuriko
        @marcj091 said in Program upload error stickC plus2:
        hmmm i think you should pay attention to this line
        are you able to show your code?
