Display on during deep sleep?
  • Currently, going into deep sleep (or even light sleep) shuts down the display. I was wondering how we can get the M5stack to go in deep sleep without powering off the LCD.
    Say I want to display something and then keep it on for a minute, during which I don't need any CPU/WiFi/BT/etc. functionality, so those can be powered down. After a minute the CPU should boot the sketch again as if it was rebooted/awaken.
    This behavior was possible if I attach my own LCD to the ESP8266 and I believe it is possible with the ESP32, but why does M5stack switch off the display if I only want to make the ESP sleep? I believe the LCD should power down only if I call M5.powerOFF() and not when I call esp_deep_sleep_start().
    TL;DR: how to enter deep sleep while keeping the LCD on?
  • @m5er
    You can change powerOFF() function
  • @watson, thanks for the screenshot. However, this solution doesn't work. As mentioned in my original post, the problem is that esp_deep_sleep_start() itself turns off the display. So changing the powerOFF() function won't solve the problem.
    In fact, try this minimal sketch and see how sleeping turns off the display.
    #include <M5Stack.h>
    void setup(){
      M5.Lcd.println("Setup");
      if(M5.BtnA.wasPressed()) {
        // wake up after 5 seconds
        esp_sleep_enable_timer_wakeup(5000000);
        // start deep sleep. Display goes out!
        esp_deep_sleep_start();
      M5.update();
    Can we have the display on during deep sleep at all?
  • Hello, @m5er ESP32 can enter 5 kinds of power saving modes. esp_deep_sleep_start(); means deep sleep mode. You can try the light sleep mode by using esp_light_sleep_start()
    You can refer to this article.
    https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/system/sleep_modes.html
    Looking forward to your good news~
  • Thanks @watson. As I mentioned, I also tried with light sleep, but the display again turns off. Do you know of any command to put the ESP in sleep mode without turning off the display?
  • Is there a solution to this problem? I find it really strange that we can't have the display on during light/deep sleep. This harms all kinds of low-power applications that rely on a screen.
  • I can't believe this problem has no solution: keeping the display of M5stack ON during light or deep sleep. It should be trivial and yet no one on this forum can present a working solution. This seems to be an impossible task!
  • @m5er said in Display on during deep sleep?:
    The reason no solution exist is because having the screen on goes against the purpose of deep sleep and also because it’s such an unusual question that you have asked, no one has yet to think of a solution in the esp32 world.
    Please be patient, M5Stack is still a young project and not everything is thought off until the end user posses a query. If you discover a way to do please let us know but in the mean time please continue to wait patiently.
  • I agree with @ajb2k3 that M5Stack is a young project, so that indeed explains the lack of such queries. However, I don't think my use case is unusual - I can think of a lot of applications that would benefit from sleeping while the display is on, such as: a clock showing hours and minutes only (so waking up only once a minute); sensor monitoring application (e.g. temperature, humidity, etc.) that constantly displays the latest values and wakes up once each X minutes to update measurements; displaying the number of twitter followers, likes, page visits, etc. In all these use cases it is useful to have the CPU sleep most of the time while the display remains on.
    In any case, it would be great if someone can present a working solution. It is probably just a few lines of code, but I just can't seem to get the right ones.
  • @m5er
    Thank you.
    What some people dont know is that the esp32 is not like an arduino.
    the esp32 has 3 cores, 2 primary and 1 Ultra Low power.
    In true deep sleep, the primary core are deactivated and the basic "Upkeep" code is off loaded to the ULP.
    Because the M5Stack is based on the ESP32 and not much is understood about the ULP, very little progress has been made on deep sleep.
    In theory, from what I have read the ULP could maintain a low power screen for a Like (to use your example) and then wake up the core to take the sensor measurements before storing them (for the ulp to recall and display) putting the cores back to sleep.
    If you are interested in leaning more, look into the ESP32's ULP (Ultra Low Power core)
    dernières valeurs et se réveille toutes les X minutes pour mettre à jour les mesures; affichage du nombre d'abonnés twitter, de likes, de visites de pages, etc. Dans tous ces cas d'utilisation, il est utile de laisser le CPU dormir la plupart du temps pendant que l'affichage reste allumé.
    Dans tous les cas, ce serait bien si quelqu'un pouvait présenter une solution de travail. Ce n'est probablement que quelques lignes de code, mais je n'arrive pas à trouver les bonnes.
    I'm editing this old post... Do you have a solution?
    Pierre
  • @PierreD
    Random Nerd Tutorials published by Rui and Sara Santos have a tutorial how to use the deep sleep mode on the ESP32and how to store data in the RTC memory:
    https://randomnerdtutorials.com/esp32-timer-wake-up-deep-sleep/
    I havn't tried it out yet, but it probably should also work with the M5Stack ESP32.
    @PierreD Tu trouves une code exemplaire de programmation pour le sub-ordnateur ESP32-RTC au site de Rui et Sara Santos à https://randomnerdtutorials.com/esp32-timer-wake-up-deep-sleep/
    bonne chance crami25
  • Hello Crami25,
    Thank you for your help.
    I took the time to try, to test.
    For sleep, it's OK.
    I made a small example but it doesn't work every time ???
    On the other hand, I wish to wake up with the buttons.
    I've searched the schematics:
    Button A GPIO39
    Button B GPIO38
    Button C GPIO37
    Following the example of this site:
    https://randomnerdtutorials.com/esp32-external-wake-up-deep-sleep/
    ext0
    In this example, the ESP32 wakes up when the GPIO 33 is triggered to high:
    esp_sleep_enable_ext0_wakeup(GPIO_NUM_33,1); //1 = High, 0 = Low
    Instead of GPIO 33, you can use any other RTC GPIO pin.
    #define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds /
    #define TIME_TO_SLEEP 10 /
    Time ESP32 will go to sleep (in seconds) */
    //#define BUTTON_PIN_BITMASK 0x8000000000
    void setup()
    Serial.begin(115200);
    M5.begin(true, false, true);
    esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
    Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) + " Seconds");
    esp_sleep_enable_ext0_wakeup(GPIO_NUM_39,0); //1 = High, 0 = Low
    //esp_deep_sleep_start(); //entre en someil profond
    M5.update();// update button state
    if (M5.BtnA.wasReleased())
    if (M5.BtnB.wasReleased())
    if (M5.BtnC.wasReleased())
    M5.Lcd.fillScreen(WHITE);
    M5.Lcd.setTextColor(BLUE);
    M5.Lcd.setBrightness(100);
    M5.Lcd.setTextSize(2);
    M5.Lcd.setCursor(40, 60);
    M5.Lcd.print("Temperature: ");
  • Hey @pierred and @crami25 - no offense, but it looks like you are hijacking this thread to discuss a different topic, i.e. how to wake from sleep. The original topic of this thread is "how to enter deep sleep while keeping the LCD on". This is still not solved and I doubt that it will ever be.
  • @m5er During deep sleep the LCD background led draws(a lot of) current. Also you have to refresh your screen 50 times per second
    The only solution to your problem would be adding an e-ink display which doesn't need any refresh during deep_sleep.
  • Hello all
    the reason nothing can be seen on the LCD during deep sleep is that the backlight is off. The LCD backlight is driven by GPIO32 (PWM) which is stopped when the ESP32 goes into deep sleep. Luckily GPIO32 can be controlled by the Ultra Low Processor (ULP) too. Below is a small test program which implements PWM for GPIO32 with ULP C macros / assembler.
    Cheers
    #include "esp32/ulp.h"
    #include "driver/rtc_io.h"
    const int lcdBrightness = 1; // (1-255)
    void ulp_start(void) {
      // Slow memory initialization
      memset(RTC_SLOW_MEM, 0, 8192);
      // M5Stack LCD backlight is connected to GPIO32 (specify by +14)
      const gpio_num_t lcdPWMPin = GPIO_NUM_32;
      const int lcdPWMBit = RTCIO_GPIO32_CHANNEL + 14;
      // GPIO32 initialization (set to output and initial value is 0)
      rtc_gpio_init(lcdPWMPin);
      rtc_gpio_set_direction(lcdPWMPin, RTC_GPIO_MODE_OUTPUT_ONLY);
      rtc_gpio_set_level(lcdPWMPin, 0);
      // Define ULP program
      const ulp_insn_t  ulp_prog[] = {
        M_LABEL(1),
        I_WR_REG(RTC_GPIO_OUT_REG, lcdPWMBit, lcdPWMBit, 1), // on
        I_DELAY(lcdBrightness * 100),
        I_WR_REG(RTC_GPIO_OUT_REG, lcdPWMBit, lcdPWMBit, 0), // off
        I_DELAY(25500),
        M_BX(1),
      // Run ULP program
      size_t size = sizeof(ulp_prog) / sizeof(ulp_insn_t);
      ulp_process_macros_and_load(0, ulp_prog, &size);
      ulp_run(0);
      M5.begin(true, false, true, false);
      M5.Power.begin();
      M5.Lcd.println("Put something onto the LCD...");
      ulp_start();
      M5.Lcd.println("Going to deep sleep");
      esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_ON);
  • @felmue Thanks for the above routine. Works well. However i was storing a RTC_bootCount so i could display a sequence of images on the screen after waking from sleep. However it seem the ulp over rights the bootCounter stored there. How do i need to change the above code to preserve the RTC_bootCounter?
    i tried this but never worked, I am new a ULP coding, so not sure how to locate a free memory space in ULP memory. and retrive it back into the main routine.
    I_ST(ulp_bootCount, R0, 0), // trying to store my bootCounter
    M_LABEL(1),
    I_DELAY(25500),
    M_BX(1),
    and in my main code use ++ulp_bootCounter;
    please help . Thanks AndyT
  • Hello @AndyT
    please have a look at the following example which stores variables after the ULP code: deep sleep example
    Cheers
  • This post is deleted!
  • @felmue Thanks for the link. Lot of code to sift through , spent hours trying to get clues from it. Tried snipets of code out of it, But still can't fully understand what' the problem is. I think i am missing a fundamental principle, how after a SLEEP the esp32 loads all it's variables which would include
    RTC_DATA_ATTR int bootCount = 0;
    So no wonder it is 0 when the main loop runs, as it is always being set to 0 on wake up. So confused about this from the outset the code even worked in the first place.
    But it did work until i introduced the ULP program to PWM a GPIO while sleeping to keep my esp32 M5Stack LCD back light pin operating.
    if I don't call the ulp_start(void) routine before sleeping then the ++bootCount increments on each wake just fine.
    Why is the below code effecting the RTC_DATA_ATTR int bootCount = 0; ???
    what do i need to add to fix it?
    I am using the Arduino IDE. So maybe there is an issue on where the Config is assigning the RTC_ to fast or slow ULP memory. I really can't fathom it out. why calling ulp_start(void) resets my counter to 0. Please give me an explanation and solution. Cheers Andy
    M_LABEL(1),
    I_DELAY(25500),
    M_BX(1),
    // Run ULP program
    ulp_run(00);
