    AirQuality v1.1 restarts roughly every minute
    PRODUCTS
    • K
      kforjf
      Hi there,
      I recently got my hands on an AirQuality v1.1 together with the Stamp S3A. I went through the quick start guide, and tried connecting it up to WiFi, but it seems to reset itself every minute. When this happens there is a bleep sound, and the screen flashes black. This regular bleeping makes it not particularly desirable to have in my living environment.
      I've noticed a few things:
      1. The temperature readings seem to be much higher than the actual temperature. Some other posts mention this for other air quality meters, and it is not a must for my project
      2. I am powering the device via the USB C cable on the Stamp board. Is this a problem, or should it be charged via the 5Vin pin?
      I asked the GPT for M5Stack, and it recommended flashing the firmware using M5Burner to ensure its not a corrupted firmware issue. Is this really a likely cause (out of the box), and if so which firmware should I flash?
      All the best,
      Kforjf
      • robskiR
        robski
        you can disable sound and adjust timer, 60s for reset is default it does flash black like many ink displays
